Hello,
I`m new to headlight restoration, I did 2 pairs and 1 pair of really big headlights so far.
All of them turned out good, except there is on thing that really bothers me.
Headlights look like new, but if I look really close, under the correct angle I can see fine straight (usually horizontal) scratches, really fine, can`t even see them on beam with headlight turned on.
There is no point of uploading a photo, because it`s not visible on the photo...
But it still bothers me...
My process:
Wet sanding:
600 if headlight is really bad, 1000, 1500, 2000
I change directions (horizontal / vertical) each time I change sandpaper so I can see if there are any scratches left behind, once I don`t see any scratches I go another pass just to be sure..
Each time I check for left over scratches on wet and on dry clean headlight...
Polishing:
I have 3m system pads and compounds...
3M Perfect-it III Fast Cut Plus Compound with green pad
3M Perfect-it III Extra Fine Compound with yellow pad
3M Perfect-it III Ultrafina SE Polish with blue pad
I can start to see those tiny scratches when I`m working with fast cut plus, because they are straight I know that they are not made by polishing...
I can work how much I want with fast cut, but they don`t disappear...
Anyway I do 3 passes vertical and horizontal before applying fresh compound, I repeat this 3 times...
Then the same for yellow and blue compounds...
When I was working at Citroen dealer as a mechanic I had opportunity to wach my coworker at body shop xxx times as he was polishing headlights with same 3m system, using same grit sandpaper... he didn`t even use 2000grit and it was always perfect...
I`m not rushing with sanding process, I know that some things can`t be rushed... I really take my time... like 4 hours for a pair of headlights.
Any idea what could be done?
Thank you
My process:
Wet sanding:
Polishing:
Thank you
