ehuth1
- Dec 9, 2006
- 1,140
Ok lets say your getting to the job and the car is parked pretty much in a perfect area to just start washing away. Everyone share where they would start and end up to after the drying.
1. Setup your wash buckets (pre-fill) and cleaners for easy access. Try and 5S everything so it's the same everytime
2-3min
2. Pre-Rinse 1400psi Pressure Washer All Panels to remove tar, light bugs, any loose mud..... 5min
3. Start with the top and move on to the windshield (clean scmitt if necessary, then get the hood. Next spray all of the soap off and then take care of all the left or right side above the lower rockers (of course checking the scmitt for particulates) Take off the soap per side and Don't forget the front and rear bumpers
5min
4. Next Get the lower rockers from right to left then which ever side is last have your wheel cleaner ready to spray on the wheels and wheel wells. Do one side at a time and be sure to only use the bucket wash if the wheels are last. Get your old brushes out to scrub the inner wells and then move on to tires and lastly wheels. (I spray my tires with a chemical that degreases on spot and doesn't harm any wheel. So I pretty much don't have to touch the tires and barely use any hand on the wheels.) Do this step however you like. Everyone's different. 5min
5. After completing both sides of wheels, tires, fenderwells. It's time to move on and dry the vehicle off. If you have a blower it's good to use it on the mirrors, beds on trucks, wheels, grilles, rubber weather stripping etc.... This will prevent spotting later on while driving. 10min
6. Next I dry the top to bottom with a microfiber drying towel then move onto opening the vehicle up to vacuum and clean windows. Most of the time I go ahead and apply tire, trim, and fenderwell dressing so it can be drying while I'm inside the car. After I'm completely done with the interior I step back and make a circle around the car to check myself and wipe off any residual water, or tire gloss. 15-20min
A little under 50 minutes for me to complete a F-150 Supercrew 4x4 which I based this off of. I want to hear your steps to see if I can shave a few off mine. Thanks ahead of time.
