Scratched BMW painted wheels - Fixed By Toto
Totoland Mach
The dealer got this 06 530Xi and the first thing I noticed while prepping for compounding routine was the wheel faces where scratched. Upon closer inspection the recess' were deeply scratched. I think the previous owner tried to use Scotch-Brite pads to remove brake dust...and totally screwed up the surface.
Before's:
So, I used a couple of tools to correct the condition: The spoke faces were easy. Just a 6" wool pad and compound made short work of fixing these (and the lift was a blessing). I used 3M Extra Cut on the wool followed by a few passes with Meguiar's #83 on the wool.
Next, the wheel recess area (lots of damage here...the paint was dulled completely). I have an air-powered rotary 3" with wool and foam pads, so I used wool and Extra Cut. Had to do a lot of careful work because I didn't want the small, hard backing plate to contact the sides of the spokes.
I probably spent 20 minutes per wheel, but they came out superb and fixed correctly.
After's
Now I can attack the body of the car.
Toto
Man Toto you are the man by far.Those wheels look like they are brand new !!!!!!!!!!! Awesome as usual.
Hi TOTO,
Nice work as always !
So what does this small rotary tool look like and who makes it ?
Hi TOTO,
Off hand, I don't know the mfg, but I think Harbor Freight sells them along with most body shop suppliers. It's a pistol grip unit.
I use a kit from 3M that has the 3" backing plate, couple of wool pads (also superb for headlight lense buffing) and a couple of foam finish pads. WORD OF CAUTION: The small diameter and rpm of the air tool concentrates heat and you can do some serious damage to paint very quickly (I've done a few burns with this unit trying to repair scratches on tight panels where the big rotary would not fit).
Toto
As always your attention to finite detail amazes me as always - Kudos
Toto, great work. You should open up a detailing university, I know I would come..
I am also highly jealous of your detail shop....
Finished compounding the car today...now it's looking like a nice ride. Polish tomorrow and wax.
Toto
I really love the way you are ready to tackle any problem large or small. You are without question in the top three best detailers I have ever seen, and I've been around for quite a while (57 yrs.). Congrats on another super job.
Nnnnnnnnniiiiiiiiicccccceeeeeeeeeeeeeeeeeee!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
