scratches on glass windows
crackster
Hey guys just got a new car am working on and it seems to be little scratches on glass windows on the driver side? guessing could be much in the seal and its scratched it. any way to get rid of them? thanks
Is it on the inside or out? Car Pro's Ceriglass (cerium oxide) will remove light scratches in glass. Hope it's on the outside as using Ceriglass can get messy. Need to keep the glass wet. Hope you have a DA or better yet a rotary. Use Car Pro's rayon glass pads with Ceriglass. If you don't have a buffer, they do make a kit with two hand held rayon pads. If you take that route, be prepared to have Popeye arms. Good luck. :props:
cheers mate i have a look at that. i don't have a buffer or nothing atm this is just a hobbie. on which am getting stated and just using friends cars to learn. but thanks i check that out :)
Is it on the inside or out? Car Pro's Ceriglass (cerium oxide) will remove light scratches in glass. Hope it's on the outside as using Ceriglass can get messy. Need to keep the glass wet. Hope you have a DA or better yet a rotary. Use Car Pro's rayon glass pads with Ceriglass. If you don't have a buffer, they do make a kit with two hand held rayon pads. If you take that route, be prepared to have Popeye arms. Good luck. rops:
Agree. It's very messy but worth it. Also wear a mask and eye protection. You really don't want to breathe that dust in.
