the_invisible
- Sep 20, 2009
- 72
Hi,
Just curious on what to do here. I have applied a couple layers some very durable sealants on my car (DP Poli Coat). I let each layer cure for 24hrs before applying the next clear. After a while I see some light marring on the wax coat.
I know that those scratches are ON the wax and NOT the clear coat because those marrings can be induced by something as gentle as my finger tips. The marrings can be removed by IPA wipe down, so that is an indication that the marrings are on the LSP and not the clearcoat.
In the case that the marrings are induced on the clear coats, what can I do to remove them? The marrings don't bother me enough to remove them completely and reapply everything; it's too much work to do so. However, what are some great techniques to remove them?
I figured that applying another layer of LSP may remove some of the marrings on the sealants. However, I find that the more layer of sealants I apply, the easier it is to create visible marrings on the sealants.
