Scuff & Buff - Wet Sanding Single Stage Metallic Paint - 1948 Willys Jeepster
My good friend Mike Gelter recently had this 1948 Willys Jeepster painted with a single stage metallic paint system. The paint had some orange peel and while it looked good in full sun there was no gloss or crispness to the finish in any other light setting. I had an IDA CD and SV Certification Class coming up and because I had a few guys flying in from other states I asked if while they were here would they like me to set up a fun car detailing project. Everyone attending said "yes".
So I put together a wet sanding class for everyone involved and also opened it up to local car guys.
This 1948 Willys Jeepster is sitting on a Jeep CJ8 frame and running gear with a small block Chevy 350 and Turbo 350 transmission mated to the Jeep CJ8 Transfercase. She runs and drive nice! The paint just needs what I call a Scuff & Buff.
Here's a few pictures showing the orange peel...
Continued....
Scuff & Buff
It's not generally a good idea wetsand single stage metallic paint jobs because you're sanding directly on the metallic flake and if you sand too much or compound and polish too much you can alter the appearance of the paint job in a negative way.
I told Mike the owner about the difficulty in wetsanding single stage paints but he really wanted the finish to have more pop, more gloss and shine. So I told him I would do what I call a Scuff & Buff job.
A Scuff & Buff is where you just LIGHTLY sand the surface using high grit sanding papers or sanding discs. In this case we used 3M Trizact #3000 by machine. I had some guys that had never machine sanded and because there were tight areas, thin panels and raised body lines, I had everyone use the Griot's 3" Mini Polisher which is a 5mm dual action polisher. When you attach the 3" 3M Trizact sanding discs to the backing plate you turn the polisher into a slick little machine sander that is SUPER EASY to control and guide over the paint. I
t's also really easy for even a beginner to use precision control over the tool to sand along edges and raised body lines.
I did a quick demonstration on how to machine sand and then turned the team loose on the car. (I was conducting certification tests).
Here's a test spot we did to see what it would take to remove the sanding marks. Sorry no pics of the guys using the rotary buffers with wool pads as everyone was buffing.
Here's the Jeepster with a coat of SONAX High Speed Wax on it drying...
Continued....
Here's the products we used...
With these two tools along you can really tackle just about any car or boat detailing project under the sun....
And here's the team that made the magic happen!
From left to right...
Craig, Warren, Paul, Rohan, Tim, John and Frank
Continued....
Parting shots....
The flake just comes alive in the sun!
Classic Willys Jeepsters have a very unique personality....
The perfect run-around rig for sunny South Florida!
This is the last car to go through Autogeek's Show Car Garage for 2016. Stay tuned as next week I'll put all the cars that went through our garage into a single thread.
:dblthumb2:
As you mentioned Mike, single stage metallic paint can be difficult to sand and then compound/polish and have it come out right but I think we managed to pull it off.
It came out looking good!
Thanks for the opportunity to work on it.
Mike, quick question...
With the 3M Trizact sanding discs did you use an interface pad and what speed did you run the Griots machine at?
I assume the next steps were the Flex rotary with a wool pad then the Flex DA with the orange foam pad.
It turned out fantastic!
Yes.
Normally it's a bad idea to wet sand single stage metallic paints. It's okay to wet sand single stage paints, just not METALLIC single stage paints and the reason why is because you are sanding and buffing directly on the metallic particles.
I explained this to the owner, Mike Gelter. Understanding the issues he still told me it would be okay because the paint looked so dull and flat unless the Jeepster was in the sun.
I then called the painter and talked to him about sanding on the single stage metallic paint. He told me that while he agreed it's not a good practice, he said they sprayed a LOT of paint on the Jeepster and he didn't think it would be a problem to use lightly sand it.
I told him if we took on the project we would stick with high grit sanding discs and this is exactly what we did, we used the 3M #3000 sanding discs.
To make the sanding even LESS aggressive and because some of the guys had never wet sanded before, I did have them use an foam interface pad between the backing plate and the sanding disc. If you look through the pictures carefully you can see the foam interface on all but one of the Griot's 3" polishers.
I see one guy sanding without the interface pad and that could be because when he switched to a new sanding disc he removed the old sanding disc PLUS the interface pad. If a person wasn't paying attention this could happen. But originally I did set them all up with interface pads.
I was doing IDA SV testing at the same time so I couldn't monitor the wetsanding project as much as I would have liked to.
As for speed setting, I did a demo showing the guys to start out at a low setting to see if the low setting would maintain pad rotation. If it would then go for it. If not then gradually increase the speed setting until pad rotation was maintained.
In my demonstration I found I could maintain pad rotation on the 4 setting. Remember, unlike compounding and polishing you're NOT pressing down hard but instead it's a light touch, about the weight of the machine.
Correct.
Here's the deal with the pictures.
First - Everyone is busy. The guys sanding are busy sanding, not playing photographer. Me? I was giving tests, not playing photographer.
Second - Because we sanded with #3000 Trizact, we tried to remove the sanding marks using an LC Orange Hybrid pad with SONAX products on the FLEX 3401 aka the BEAST. We found that while it worked with enough buffing it was not fast enough or effective enough. So we switched over to LC wool cutting pads on the FLEX PE14 Rotary Polisher and that did the trick.
My goal was to keep the guys and the process very NON-AGGRESSIVE due to complications and risks of sanding AND compounding with rotary buffers on single stage metallic paints.
It's very easy to alter the appearance of the paint in a negative manner. You can instill what are called Tiger Stripes from buffing and simply screw up the paint job by sanding. Again I would not have done this project without first explaining the risks to the owner and talking to the painter.
I'm happy to say we got lucky, even though I don't believe in luck.
We only mildly reduced the orange peel appearance but the sanding, compounding and polishing fixed the dull appearance issue and now the paint has amazing gloss and shine in both the sun and out of the sun.
Here's a picture Mike posted to his Facebook page a few days after picking up the Jeepster
Looks happy to me and the Jeepster looks great! He also sent me a very nice thank you message for taking on this project.
Thanks. All the credit really goes to the team of guys that did the majority of the work. A few days later I used the SCANGRIP Swirl Finder Light to inspect the results and found a few places with sanding marks still in the paint so I compounded them out, polished and re-waxed before turning the Jeepster back over to Mike. The grunt work was all done by the team though.
For the record, I don't think I'll ever take on a single stage metallic wet sanding project again... it's just too nerve racking for me and I'm not comfortable with this type of paint work.
Thank you for the detailed explanation Mike. I learned a lot as usual!
