If you prep the surface and its squeaky clean. There should be no issues bonding.
Sounds good. But I've often wondered about layering. It may be clean, but it sure isn't squeaky.If you prep the surface and its squeaky clean. There should be no issues bonding.
It may be a dumb question but I've been curious. How do you know if you are having a sealant bonding problem? Just that it wears down quick or do you see a problem when applying and buffing?
