Sealant Glaze
FlawlessMustang
I applied Klasse AIO after claying and using TRIX about 2 weeks ago before a lllloooooonnnnnnggggggg line of storms hit. We've been getting rain here in Tennessee almost everyday for the past 2 weeks. I'm wanting to apply my Klasse Sealant Glaze as soon as I have some good weather, but i'm wondering if I need to take any steps in cleaning it before applying the sealant glaze? I had posted up a thread early last week, but since i've had almost 2 weeks go by, I wanted to double check and make sure I don't need to apply the AIO again or take any additional steps.
Can I just wash, dry, and apply the SG?
Thanks! By the way, after I applied the second coat of AIO, it made a HUGE difference. My surface is so much more slick now and looks so much cleaner. I actually wouldn't mind applying another coat of the AIO. Would it be useless to apply another coat of the AIO since I applied 2 coats two weeks ago?
Because there was a couple weeks and some bad weather, I personally would use KAIO first and then get at least one coat of SG applied.
Ok thanks! Also, if there are water spots on the car before applying AIO, should the AIO get rid of the water spots or will the AIO cover it up and try to seal the water spots in?
KAIO is primarily a chemical cleaner that leaves behind some protection. It will / should remove the water spots and not cover them up.
