Sealing asphalt driveway - 1st time - suggestions ?
CheckeredFlag
I have an asphalt driveway that hasn't been re-sealed for a couple of years, and have been thinking about doing it myself
Looks easy enough
I know it has to be cleaned first, and I already bought some crack filler and some trowel patch to take care of that part ...
my question is: there seems to be several different kinds of sealers ... What have you used ?
How long should I expect it to last ?
Are there different "grades" of sealer ? (Some heavier duty than others ?)
I'm thinkin this may be one of those - "You get what you pay for" kinda things
TIA
I am in the same position you are in and around 1 year behind you. I already did the research.
You get what you pay for, and there are 2 general guidelines I learned:
1. The more solids in the sealer, the better (and more expensive) the product will be.
2. The warranty length is telling as well and supports #1. A longer warranty usually means better quality and more solids left after liquids evaporate and cure.
Over the last 5-years a new set of formulas considered airport, racetrack or pavement-grade has emerged. This grade of sealer has more durable acrylic polymers and lasts longer than other formulas. Some come with a 10-year warranty.
Coal-tar and asphalt sealers seems to be the 2-types that are sold in the retail channel (Home Depot, Lowes, etc...). Each has their pros and cons. I will be getting an airport-grade sealer next year.
