Seeing the visual difference in polishes/compounds
MobolWerks
Hey everyone,
Thought I would write a simple, but informative post about teaching yourself which polish to grab for which project.
What I did was simple. Tape off (3) seperate squares (18" x 18").. A quick note, I had very similar scratches, swirls, etc accross my entire hood so it was fairly easy to see which polish was removing which defect.
After taping my squares, I began with some Menzerna Nano in my first square.. After that I began on my second square with some Wolfgang Total Swirl Remover and finished it with some Wolfgang Finishing Glaze.. Finally, I did a Meg's 105/205 combo on the third square..
Under light you can definately see the difference - you do need lights though, cause I couldn't tell as much difference under just the sunlight in my driveway.
Try it out cause I would love to hear some feedback from everyone, or even some better suggestions on polish and compound choice
Good Tip. Thanks for sharing! I will try it out on my next paint correction.
That's cool. So I'm going to go out on a limb and guess that the Megs twins removed most of the swirls and that the WG twins finished down the best?
I would like to know what your results were too.
