seeking ink recommendation for plastic spray bottles
tattooman
Hello friends.
I've started mixing my own stuff in spray bottles. The problem though is that regular sharpie markers don't last very long on the plastic bottles, the ink doesn't want to stay on or "stick" very well on the plastic. So my question is how do you guys mark your bottles ? Do you use a different kind of marker with an ink chemistry that's more compatible with plastic spray bottles ?
Thanks
I’m not sure why Sharpies not staying on your bottles.. For me they work great and last forever. The only way I can remove it is with a Magic Eraser.
They last on these bottles too.
p-touch machine with the plastic laminated tape. sams club and/or costco for around/less than $30...
0001250264346_A
Hmmm, that is interesting. I might be doing something wrong if that isn't working for me. I'll try again with a new sharpie, and clean the plastic bottle first with alcohol to remove any film that might be left over from the manufacturing process.
Make sure you’re giving it a few minutes to dry before you start messing with it.
Sharpie offers an industrial marker. It’s labeled as Super Permanent Ink. They state that-
Specially formulated ink for industrial, laboratory, and commercial use
Remains permanent under most chemical washes and extreme heat and steam (up to 500° F)
I would try marking them empty. If u have already filled them the make sure the bottle and solution r room temp. As not to cause condensation on the bottle cause the shrapie not to set and easily be removed
Sent from my SM-G955U using Autogeekonline mobile app
I put blue painters tape on them and write on that. If the tape overlaps it'll stick to itself and stay put until you don't want it to. Allows me to change what's in the bottle going forward.
I use a label maker like visitor, one label on the side and one on top of the spray nozzle.
Believe it or not Amazon still carries the old DYMO embossed label maker for $6.
Sharpie ink will come off if you have organic solvents in the bottle - like isopropyl alcohol, Meg's All-Season Dressing, that sort of thing. It won't come off with most aqueous solutions, things that are mixed with water, like ONR solution. But it's hard to know how it will react with any given liquid until you try it. I label my bottles with a Sharpie, then I put a strip of clear packing tape over it. This keeps any fluid off the ink, but if I ever want to change the label, I can peel off the tape and wipe off the ink with isopropyl.
