SEMA 2026
Setec Astronomy
Big day for Autogeek/Sonax/Vision with the reveal at SEMA of the new Flex polisher(s?) that apparently will be exclusive to Autogeek, if I understood that correctly.
I imagine a lot of other new product introductions; let's see what happens. Show opens at Noon eastern time, so a little more than 3 hours from now--Flex reveal at 1:30 EST.
Getting the updates from SEMA is always a good thing every year.
Griot's did a new product video. New G15/21, which were out already. Some new mod attachments (bendable slim wand). Stinky Be Gone Odor Exterminator. And some aerosol products - speed shine, ceramic tire dressing, wheel-tire-mat cleaner. ~Mid January for the aerosols.
Per the other thread, it's exclusive to Autogeek for the next 6 days. https://autogeekonline.net/threads/sema-2026-flex-launch.127727/
TRC MF detergent: https://theragcompany.com/products/advanced-microfiber-detergent?variant=67299484959091
32 oz, 1 gallon (out of stock)
1 oz for presoak. 0.5, 1, 2 oz for lightly, medium and heavily soiled wash
advanced-microfiber-detergent-32oz-front-web.webpadvanced-microfiber-detergent-32oz-back-web.webp
Advanced Microfiber Detergent represents The Rag Company’s commitment to advancing microfiber care. Developed over eight months through approximately 30 formula iterations, AMD brings together hands-on microfiber experience, specialized chemical expertise, and extensive practical testing. The result is a detergent developed to deliver effective cleaning, address challenging detailing-product residues, and prioritize the feel and performance of microfiber after washing. We’re not simply trying to get towels clean. We’re trying to help people get more out of the microfiber they invest in. Advanced Microfiber Detergent: A love letter to microfiber.
Why You’ll Love It:
  • Balances cleaning performance, look and feel, and long-term textile stability
  • Effectively removes difficult contamination from modern spray sealants, resin-based products, and advanced detailing chemistry
  • Cleans the entire substrate of the towel, not just the surface, preventing brittle, hydrophobic, or starched fibers
  • Utilizes a specialized blend of surfactants to minimize fiber damage from cleaning and heat cycles
  • Maintains optimal post-wash towel feel, perceived rinsability, color retention, and maximum absorbency
  • Developed over eight months through approximately 30 formula iterations combining hands-on microfiber expertise and masterful chemical formulation
  • Blended and bottled in a specialized, state-of-the-art facility in the Northwest for consistent professional-grade quality
Watched a fair amount of content on SEMA. Haven't seen anything game changing. Just tweaks to existing products or those products they claim are new are just slightly different than existing products.
some new Autofiber Wash Pads - Tap Out and Another one that comes with a mini mitt, i guess?
Flex 3361 - Cordless DA/Rotary/Forced Rotation
Big Performance. Small Spaces. Precision Perfected.
Reach the trim, pillars, recesses, and wheel spokes that a full-size machine can’t with the FLEX 3-in-1 Mini Polisher Set. This cordless mini polisher combines rotary, random orbit, and gear-driven polishing in one compact tool, and a tool-free quick-change system lets you switch between polishing actions and between 1-in., 2-in., and 3-in. backing plates in seconds. The brushless motor runs from 1,000 to 4,000 RPM with a 6,000 RPM turbo setting, controlled by a touch-sensor speed strip with an LED RPM display and a speed lock. A belt-driven design is optimized to reduce vibration and noise, and an integrated detailing light with three color temperatures puts light right on the work surface so you can inspect defects as you correct them. The kit includes the accessories for all three modes: three backing plates, a 1-in. sanding plate, 3mm, 6mm, and 12mm random orbit adapters, a rotary adapter with extension/locking pin, and a 6mm gear-driven adapter. For paint correction specialists, ceramic coating installers, and mobile detailers, it is a dedicated spot-correction and detail polisher for areas such as A-pillars, mirror caps, bumper recesses, spoilers, chrome, wheels, headlights, and interior trim.
FLEX 3-in-1 Mini Polisher Kit Features​
  • 3-IN-1 ROTARY, RANDOM ORBIT & GEAR-DRIVEN POLISHER: One tool covers three polishing actions. Use rotary mode for direct, concentrated correction on small areas; free-spinning random orbit with a 3mm, 6mm, or 12mm orbit for controlled polishing and finishing; or 6mm gear-driven forced rotation, which keeps the pad turning on a fixed path instead of free-spinning.
  • TOOL-FREE QUICK-CHANGE SYSTEM: Swap between polisher types and between 1-in., 2-in., and 3-in. backing plates without tools, so you can move from a narrow pillar to a mirror cap to a wheel face without reaching for a second machine.
  • 1-IN., 2-IN. & 3-IN. CAPACITY IN EVERY MODE: All three backing plate sizes can be used in rotary, random orbit, and gear-driven modes, letting you match pad diameter to the width of the panel or trim piece you are working on.
  • BRUSHLESS MOTOR WITH 6,000 RPM TURBO: Variable speed from 1,000 to 4,000 RPM, plus a 6,000 RPM turbo setting intended for wet sanding. Soft start helps keep product from slinging at start-up, and constant-speed electronics are built in to help maintain speed under load.
  • TOUCH-SENSOR SPEED CONTROL WITH LED RPM DISPLAY: Slide a finger along the touch strip to change speed, double-tap the ((6)) icon for turbo, and press the lock button to hold your selected speed. The LED display shows your RPM at a glance, and the touch sensor works while wearing nitrile gloves.
  • BELT-DRIVEN DESIGN: The belt-driven drivetrain is optimized to reduce vibration and noise, helping you keep a steady hand during close, detailed work.
  • INTEGRATED DETAILING LIGHT: A built-in 130-lumen light illuminates the polishing area, with selectable 2500K, 4500K, and 6500K color temperatures and a 90 CRI rating. Press the light button to turn it on or off, and press and hold to change color temperature.
  • COMPACT 24V CORDLESS PLATFORM: At 280 mm long and 0.9 kg without a battery, the tool is sized for close control around tight contours, and cordless operation keeps cords off the paint when working in a bay or on a mobile job.
  • COMPLETE ADAPTER & BACKING PLATE KIT: Includes every adapter needed to run all three polishing actions, three backing plate sizes, a 1-in. sanding plate, and a rotary extension that doubles as a locking pin for changing gear-driven backing plates.
FX3331-MAIN__68950_webp_80.jpgfx3361-infographic-4v1__28900_webp_80.jpgfx3361-infographic-3v1__38700_webp_80.jpgfx3361-infographic-2v1__41197_webp_85.jpgfx3361-infographic-1v1__47514_webp_80.jpg
Flex 24V Dust Blower - https://www.flexpowertools.com/dust-blower-fx5461/
26_0922_flex_photo_fx5461_feature3_1.webp26_0922_flex_photo_fx5461_feature4_1.webp26_0922_flex_photo_fx5461_feature2_1.webp26_0922_flex_photo_fx5461_compact_1.webp26_0922_flex_photo_fx5461_feature1_1.webp26_0922_flex_photo_fx5461_hero2.webpfx5461-z_flex_dust-blower_3q-dwn_bare_26-0909_main_1000.webp
Features​
HIGH-POWER CORDLESS AIRFLOW​
Delivers up to 660 MPH maximum air speed and 43 CFM airflow to quickly remove dust, dirt, sawdust, drywall debris, and jobsite contaminants from a wide range of surfaces
IDEAL FOR AUTOMOTIVE DETAILING & JOBSITE CLEANUP​
Perfect for cleaning vehicle interiors, floor mats, vents, dashboards, consoles, polishing pads, drywall sanding pads, anchor holes, concrete joints, HVAC equipment, and workshop spaces
AGITATOR NOZZLE FOR EMBEDDED DIRT REMOVAL​
Patent-pending agitator nozzle helps break up and remove stubborn dirt, dust, and debris from floor mats and textured surfaces without the need for pneumatic air hoses
QUICK-CHANGE NOZZLE SYSTEM​
Tool-free nozzle interface enables fast accessory changes to move seamlessly between detailing, dust blowout, inflation, and precision cleaning applications
VARIABLE SPEED CONTROL + TURBO MODE​
Precision trigger provides instant activation with no delay; choose from three speed settings and Turbo Mode for maximum control across light-duty and heavy-duty cleaning tasks
LED HALF-RING WORK LIGHT​
Integrated LED illumination improves visibility in dark, confined, and hard-to-reach areas, making it easier to clean under seats, inside equipment, and around HVAC components
VERSATILE ACCESSORY KIT INCLUDED​
Includes an agitator nozzle, brush nozzle, inflator nozzle, 1/4-inch nozzle, 4-inch nozzle, and paper filter for greater versatility across automotive, HVAC, construction, workshop, and maintenance applications
THE FLEX ADVANTAGE​
20% more power with 24V lithium, 25% longer runtime with THERMA-TECH™ heat management, up to 50% faster charging with high-power, dual fan chargers
FLEX 5-YEAR LIMITED WARRANTY​
Register your new FLEX tool, battery, or charger within 30 days of purchase to receive a 5-year limited warranty
Koch Chemie Ceramic Neo C0.03 - 3-year coating with up to 1-hour wipe-off
Ceramic Neo C0.03​
Innovative next-generation ceramic sealing
Ceramic Neo is the innovative next-generation ceramic sealant that impresses with its unparalleled performance, such as remarkable hydrophobicity and unmatched color enhancement with extreme deep gloss. Thanks to the strong sealant, the feel is noticeably improved and the treated surface is protected in the long term. The hardened ceramic sealant protects the paintwork from environmental influences such as UV radiation, road salt, bird droppings, and rust film, reduces mechanical damage, and thus contributes significantly to maintaining or increasing the value of the vehicle. The easy-to-clean properties allow the treated surface to be cleaned gently and easily by hand. Furthermore, depending on the level of use, a very long service life of several years can be achieved. With professional application, the degree of gloss can be maintained for years.
Long video but if you watch it on YouTube there are chapters for each manufacturer.
I also saw that one. I also watched the one by Kiev. Kiev seems to be in a mood.
Carpro has a new RW. I'm liking Adam's Hoseless and Waterless Wash a lot right now so I don't think I'll jump to that yet. May try it at some point.
Are you talking about the Flat Out pads, or is there also a Tap Out? The other one seemed to be a Fine Detailing collaboration product.
That blower from Flex looks interesting, also interesting that CarPro came out with a rinseless after all this time of people using EcH20 essentially off-label as a rinseless. I personally don't like the oiliness of EcH20 as a rinseless, so I'm intrigued by RinseX.
There is a new one called Tap Out. I didn't see a name on the fine detailing collab. Looked like a wash pad, mini mitt and wash stick pad.
