SF3500 and SF3800--What Happened?
Setec Astronomy
I asked this in another thread, but I don't think it got answered.
Back when SF3500 and SF3800 were SF4000 and SF4500 (is that what they were? or back when they were PO85RD and PO106FF), I thought they had the same gloss and different cut?
I'm looking at a really old Menzerna sheet from 2006, where PO106FF is 2.5 cut, 5.0 gloss, and PO85RD was 1.5 cut, 5.0 gloss. I thought it was similar when they went to SF4000/SF4500, except I think that's when they went to the 1-10 scale. Anyway, here's the latest chart from the AG store:
So now not only is the cut different, but the gloss is different also, and apparently the 1-10 chart goes to 10+ or even 11 for an LSP, which is ok because now it matches my amp.
Anyway, does this represent an actual change to the product, or simply a refinement of the rating system, and why does nothing ever stay the same in Menzerna land and why don't they tell us when to start calling them Hueys instead of choppers?
(Couple of movie references in there)
I am not a smart guy and now seeing this chart makes me even more dumber!!....LOL If it wasn't for how well the product was in performance...I would have switched brands long ago. Let's not forget it is called Jescar too. Very confusing no matter how you look at it.....I am just a dumb ol man!
Here's the 2013 chart. 4000 & 4500 we both 10's in gloss.
The confusion with Menzerna is why I use other lines now. Optimum and HD have changed/reformulated their polishes but it's a lot easier when the new stuff says Cut/Compound or Polish, no numbers,no charts and no headaches.
Thank you! I knew I wasn't imagining that...so how did 4000 go down to 9 and 4500 go up to 10+ when they changed to 3500/3800? Was it a product change, or a chart refinement?
In all my time using Menzerna polishes I never agreed with any of the charts stating that 3500 & 3800 cut and finished the same.
3500 has always been in the class of normal finishing polishes and the charts that state 4 for cut and 10 for finish were accurate. 3800 has always cut less and finished better than 3500 and should have been labeled 2 for cut and 10+ for finishing. Another thing I don't agree with is per the above chart they claim to handle 3K. I don't agree with this either and 3800 should be labeled for 5K grit removal.
Well, they didn't, in the chart mcate posted above, and the 2006 chart I quoted, the cut was always different, it was the gloss that was the same.
Well, ok then. Perhaps when the scale was 1-5 they kind of got rounded off to the same gloss, and that just got carried over to the 1-10 chart, and now they've finally adjusted it to what you have found.
The reason I'm asking about this besides just trying to keep up, is I have a bottle of Blackfire Finishing Polish from a long time ago when it first came out and was supposed to be very close to PO106FA, and a bottle of SF4500 from a couple of years ago, and I just want to know what numbers to "assign" to them, the old numbers or the new numbers...but what you're saying is they are the same and just the charts have changed so the freshest numbers are accurate for my old product.
I don't agree SHC is a 10 cut and 6 gloss, more like -900 for gloss! Man that stuff is potent! I have never really used much 4000/4500 but when I did it was just 4000 after 2500.
Exactly why I stopped using them. There are so many other products that are just as easy to use and preform just as well.
I haven't outright stopped using them, but I was disappointed enough in the new labeling to not invest in more of their product, and concentrate on Meguiar's and Rupes polishes.
Aside from that, the Meguiar's is just so much easier for me to use. The Rupes polishes are nice too, but not as easy to wipe off as the Meguiar's.
Good news is that I still have a LOT of Menzerna, and if I find bottles of the last labeling, I buy them.
My feeling is the charts are all over the place but 3500 is still the best finishing polish out there. The cars just shine after using it. Especially black. Then 3800 is also the best jeweling polish out there. It doesn't have the cut of 3500 obviously but it doesn't have to. It's the perfect maintenance polish for cars that are in incredible condition.
Menzerna is only good at making buffing liquid!!!
They are NOT good at:
Consistent labeling practices
Descriptions
Simplifying names of products
CHARTS
Their charts have been so confusing for years and never made sense. The current one is the closest to making sense....
Descriptions
CHARTS
Exactly right.
Maybe they don't care about a new influx of followers (i.e. newbies, which equals more income).
I did a TON of reading on here before pulling the trigger on my initial set up. Menzerna was certainly near the top of my list.
However, the charts threw me off (WAY off) and are still confusing to this day. I instead chose other products that have clear-cut descriptions and are even color-coded to their respective pads. (To start).
Again, if Menzerna were even the least bit clear in their "charts", they might find a few more detailing dollars from the masses. JMO
I’ve always loved Menz products. I never used 3800 much as I found it good for jeweling and not much more, but 3500, wow. A Goldilocks polish for me, just right cut-great shine. I have shifted to Jescar Compound over Menz 400. Jescar Compound is easier to wipe off and gives just as much cut and gloss as 400. I’ve got most of the other Menz mid range polishes and though I don’t use them regularly I know they are there and will do their job on finicky paints. The thing with Menz is you have to work them since they are diminishing abrasives. People coming over from Meguires just don’t “get” Menz polishes. There is a learning curve with Menz.
