Shaving Cream Foam
InTheBuff
Can anyone advise on what products and equipment do I need to make that nice, tight clingy shaving cream foam to spray all over my vehicles?
Foam cannon, pressure washer and DP xtreme foam shampoo
You can use a regular Foam Cannon that just runs off your garden hose, or you can opt for the new Foam Cannon HP that runs off your pressure washer. I have both foam cannons, but only having very recently gotten the Foam Cannon HP since AG just came out with it.
The Foam Cannon does a nice job of foaming up your vehicle, but the Foam Cannon HP with a pressure washer will turn your vehicle WHITE...it's amazing.
Hi, I have the PW the FC and the DP Extreme. I don't seem to be getting the results that all of you are getting. I tried 2 and 4 ounces and the results are only OK. How many ounces are all of you using? I'm also sure that my FC is dailed in. I made sure of that...Thanks.
2-4oz should give you plenty of foam, just remember to fill the rest of the bottle with water and then shake it up real nice. The PA dial setting should be set all the way down to the PA- setting. At first I thought it was PA+ for soap, but it's actually PA-. Finally, adjust the front nozzle. The default setting is to spray in a sharp stream but you have to twist the spray nozzle about 90 degrees until it's spraying in a large fan spray. If I remember correctly I don't open the nozzle all the way because then the fan becomes too large but I do have it set almost completely open.
While DP Xtreme Foam will deliver the best foam, you should be able to produce amazingly nice foam with any good foaming car wash soap such as Meguiar's Gold Class.
