ShineMate EB212 3-inch Polisher Overview & Review
DFB
At the end of 2020, I made the move to battery powered polishers. Previous to this, I had been using a single dual action polisher kit that was purchased from Waxit back in 2010. This was essentially an entry level 12mm dual action polisher fitted with a 6-inch backing plate and came with an assortment of Menzerna compounds and Lake Country CSS Flat foam pads.
Waxit still offer these kits via the ShineMate brand, which are an excellent starting point as they include everything you need to get up and running. Being a smaller machine, they are more approachable for the beginner.
To coincide with the Black Friday sales in 2020, Waxit launched the all-new ShineMate EB351 range of cordless battery powered polishers. This included a 12mm 3-inch, 12mm 5-inch, 15mm 5-inch and a 21mm 6-inch machines. There was also a 5- and 6-inch rotary. Each could be purchased as a skin, or via a machine/battery/charger kit. Batteries and chargers could also be purchased separately.
What sold me on these battery powered ShineMate’s was the price and availability. Back then, Rupes had only the one battery polisher, the micro iBrid Nano. The major tool brands only sold large rotary polishers. Flex was the only brand to offer a full suite of battery powered polishers in micro, mini and full size machines. But the price of those Flex polishers was astronomically high in Australia. For perspective, a single Flex 5-inch machine with a charger and battery would buy you two ShineMate’s, 4-batteries, a two-bay charger, and enough change left over to buy a carry case. As the years went on and more and more competitors joined the battery powered scene, Flex have be forced to lower their prices……………………which to me is too little, too late.
Being a Chinese manufactured brand, the big gamble for the early adopters was how these ShineMates would fair against a German made Flex, or even the Italian/American made Rupes. Frankly, the ShineMate brand has enough runs on the board now that I don’t think there is even a question that these machines have the ability to go head-to-head with the establish pro-level brands. In fact, with what I have been told and seen, Rupes has fallen behind on technology, quality and reliability. They were once the leaders, now they are simply the followers. ShineMate on the other hand are faster to market, are innovating and producing highly reliable polishers that are proving themselves within the professional market. It’s telling when a life-long Rupes user says he’s lost faith in the brand, be that from a quality/reliability standpoint, but also the high asking prices.
So, back to 2020. I was wanting to add a smaller 3-inch machine to my artillery and determined I wanted to go battery powered. Rupes were nowhere in this space, and the Flex offering outrageously priced. Then the ShineMate EB351’s hit the market and immediately became my target. Once the Black Friday sales kicked in, I ended up not only buying the EB351 3-inch kit, but I also added the larger EB351 15mm 5-inch to the order. When the package turned up, for some reason I managed to score two additional batteries, something I was not going to complain about!
On first impression, the machines looked good and felt well made. In use, I quickly fell in love with the lack of a cord to manage. I also found them more ergonomic compared to the corded machine I was using, steering the unit with my right hand around the head, then supporting the base with my left hand. Battery life was excellent, weight balance superb. And having access to a 3-inch unit took my machine polishing to the next level. Operationally, the ShineMate’s do have quite a bit of chatter when winding down, but that’s relatively common with dual action machines anyway.
Over time though, I found there were some limitations to the 3-inch version of the EB351. For starters, it seemed to lack the torque and top speed potential of the 5-inch machine. But it’s the physical size of the machine that counts against it most. In this instance, both 3- and 5-inch EB351’s share the same body, which means the size of the 3-inch is too big, and therefore cumbersome for dealing with more intricate areas. In fact, ShineMate addressed this issue by releasing a smaller bodied EB350 3-inch with a different battery orientation slimmer 2.5ah battery.
I did toy with the idea of replacing the EB351 for the EB350, but hesitated. I also looked at the Rupes HLR-75, which has become known as the “stiletto” due to its unique shape. In fact, I almost ordered one but again hesitated. Late last year I had the chance to sample the Rupes and was left disappointed, it was way too noisy and very grindy. On that same day, I was made aware that ShineMate had something new in the pipeline, and reading between the lines, I suspected it would be a more compact 3-inch along the same lines of what they did with the micro EB210. A few months later, the EB212 hit the market…………………………….
Fast forward to this week and the Waxit EOFY sale, I took the plunge..............
ShineMate EB212 Overview & Specs -
Spec wise, the EB212 is a 12mm dual action polisher with a 3-inch backing plate. It’s powered by ShineMate’s 10.8-volt system that also supports the smaller EB210 and is available with 2.5 and 5.0 ah batteries. ShineMate put a high importance on NVH, to the point where this is the brands smoothest and quietest running polisher. They also worked hard on delivering a high torque machine, in turn improving cutting performance. And compared to the earlier EB350 and EB351, the new EB212 is much better sized for the 3-inch backing plate.
Some key specs –
- Light weight
- Smooth trigger action
- Double tap trigger lock
- High efficiency brushless motor
- 6 speed settings
- 50 min charging time (2.5 ah battery)
- 30 to 40 min run time (speed dependant)
- 24-month Enthusiast Warranty (tool)
- 12-month battery/charger Warranty
The EB212 can be purchased as a skin, or in kit form that includes the following –
- EB212 Skin
- 2.5 ah 10.8v Battery x1
- Single port 10.8v Charger
- 2 ShineMate Diamond Pads (red and blue)
- ShineMate Padded Case
In my case, I purchased the kit with an additional 5.0 ah battery. In the future, I can then add the EB210 skin.
On first acquaintance, the first thing you notice is how nicely sized the unit is, not too big like the EB350/351, not to small like the Flex PXE80 or EB210 with the 3-inch backing plates. The 212 has a very balanced feel with reassuring heft, with the smaller/lighter battery allowing for more control in tighter areas, while the larger 5.0 ah battery balances the weight of the head. Overall, the unit feels well made, the padded case neatly presented.
But it’s the operational characteristics of the EB212 that really set it apart. It’s just sooooo smooth and quiet running, and that’s on any of the 6 speed settings too. The unit is powered up by the press of a button, likewise changing the speed settings. The trigger is switch-like in action and not variable, however its easy to thumb the speed control buttons on the fly. A double tap of the trigger will activate the throttle lock, a single tap releases it.
Now, it’s pretty obvious ShineMate have modelled the EB212 on the Mirka AROP-B. They both look, sound and feel very similar. Unquestionably, the Mirka is better machine…………………….but not twice the price better. I did also look at getting a Mirka, but price is a huge limiting factor. And with a trigger lock, the ShineMate solves the Mirka’s biggest drawback. After watching the below video, I don’t think you are missing anything in buying the cheaper ShineMate.
So, that’s an overview of how I arrived at the EB212. From here, I need to get some time on the machine. Stay tuned.
