danieledwards12
- Jul 22, 2013
- 103
do I need to remove the filter out of the shop vac before I use it to extract water?
Your Shop-Vac doesn't have a cartridge-filter that's suitable for either wet-or-dry pickup?do I need to remove the filter out of the shop vac before I use it to extract water?
Yes. The filter is used to prevent the debris that you previously sucked up from entering the motor and blowing it up. When vacuuming up water and other liquids, take it out and get to work! When done, pop it back in.
Keep Calm & Chive On
It wouldn't blow up the motor, it will just shoot everything out of the back and damage the impeller :xyxthumbs:
