I'd also add you'll need to align the new headlights so they point correctly. Where as your OEM ones are already set to the correct angle.
That would only take a couple minutes and really shouldn't be a deciding factor to the OP.
Sent from my XT907 using Tapatalk
if $50 is no problem for OP, add just a little more, get a used Griots 3 inch on the Bay, pad interface for $3, and some sanding discs for cheap, make yours look brand new for less than $100, and still have the machine to use for all sorts of other things.
If you really don't feel like mucking-around with the original headlamps/lenses---doing things like:Should I buy new headlights for my frontier? Or do the headlight cleaners actually work? I don't really want to wet sand them, like some cleaners require. I can buy a pair of headlights for $50. Which isn't that much for me
Sanding discs ain't cheap, btw
Better off buying a kit that has one of each of the required grits
