Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 6
Should I clay and polish before ceramic coating?
Anytime I get questions via e-mail, a PM or a FB message I prefer to invest my typing time where
A: It's easier for me to share links, pictures and videos.
B: More people can read and thus benefit from the information. (no just one set of eyeballs)
The reality is, most people that contact me found me via an article I've written or a reply I've written on this forum. The thing is, instead of figuring out that the whole reason they are contacting me is because they found me via an article or answer I wrote on the forum that they to should bring their question to the forum because not only will that help them.... but it will help a future "them". If I answer everything in a private e-mail or other touch point, no one would find and contact me. It's a cycle or pattern that repeats as long as everything is shared in the public domain.
The above is kind of wordy but re-read it slowly and it will make sense.
So I get an e-mail asking,
Mr. Phillips,
I was wanting to get some guidance from you, I just bought a brand new vehicle that came from the factory 2 weeks ago and I purchased the pinnacle diamond ceramic coating pro. Should I clay and polish my vehicle prior to applying the ceramic coat?
Thank you for you consideration
Chad
Great questions Chad.
The answer is yes.
Do do the job right you want the paint perfect. Even when a car is brand new, it's been shipped, sitting somewhere in a storage yard and then on a dealerships car lot and probably washed and "touched" by a host of people during this time.
You have ZERO idea what's been used on the paint and my guess is - if you do the baggie test - the paint will fail.
If it were me and my car? I wash,
You can get into machine polishing and all the supplies you need to do this for probably around $300.00 if you go with a simple tool like the Porter Cable 7424XP or the Griot's G9
You'll need microfiber towels too and to be REAL for a moment - anyone that's going to install a ceramic coating really should have a great hand-held light to inspect for high spots. I spent half the day yesterday and after I hit the [SUBMIT REPLY] button I'll be back in the garage finishing the job of removing ceramic coating high spots off a 2001 red Corvette.
A good light would have prevented me doing the job a second time.
Mr. Phillips,
Chad
The answer is yes.
- Wash and dry
- Clay paint using an ultra fine clay
- Machine polish using a fine cut polish and an orbital polisher with a foam polishing pad.
- Use a panel wipe to remove any residual oils
- Install the coating
