TheMidnightNarwhal
- Dec 18, 2017
- 228
Hello folks, a bit long thread to give you guys/gals perspective.
I have a 2011 BMW that I drive even in winters here in Canada. I'm not that worried about rust since my car is mainly made of aluminum, plastic and galvanized steel. Now some nuts and bolts thought that's another story. But. some of my friends say I'm crazy and I do think some stuff can still rust.
That said, in the winter I usually rinse the car at a car wash manual with just water every 2 weeks-ish. When the temps raise slightly above 2c I usually do a ONR wash on the outside and re-apply some bead maker.
This leave me with under the car. My car has belly pan though up front. I thought to do, when spring arrives and temps stay above zero (meaning pressure washer can be used and outside water works) to lift the car all up, remove belly pan, spray degreaser under the car and use a pressure washer broom to rinse that off. Plus usually rust happens when above 0 and salty water arrives.
My question is, is doing all of this completely useless or will it actually do something? I assume I would have to do this weekly or every 2 weeks or else there is no point?
