Simply amazing - to good to be true????
kc's
to be or not to be?
Rotary polisher are best to be removed scratches, swirls and compounding marks left behind from the inexperienced (previous hacker) BUT also the worse in ruining one paint....it is highly recommended that rotary polishing should be only handled by experienced detailers only.
is this the right way to handle a power tool?
we cover the Basic Handling Techniques .... & remember with a high tourque level are dangerous like any other power tool
may results -
Over-extension, repetitive motions, high forces Vibration
Slips – when on improper footing, even Trips – trailing cables, Chemical hazards from cleaning solutions, electric shock
Confucius sayings "knowing oneself & knowing your enemy - will win the battle"
congrats to the 5 new owner -
unwrapping their new baby..... just like gift from above
master seech begins the class with - study of paint damage, swirls infliction
RIDS.....random isolate deep scratches???? remedy for restoration
eg. how would you clear this 1500 grit sanding marks
close up
master seech carefully showing the right techniques of handling the machine
how by using just the new optimum double side foam pad & optimum hyper spray POLISH ....enabling him to do the job
at work
remember
ta da
wipe
now
mirror finish again
how from this
now ta da
Later we move on to paint study, paint damages,
the root caused of clear coat paint failure mostly by paint poor preps job & road side car wash (harsh chemicals)
sanding marks prior painting - resurface after paint cured
a very common scene here
boils down to poor preps prior painting -
look at how factory paint still remain good on top of the worn out CC paint
Less is more - if we handle it well ...it shouldnt be repainted
the secret of handling the machine is
practice - cords behind yr shoulder, always starts at the minimum speed & gradually increase...the max is to speed 3 - 1200 will be sufficient for tropics climate like us - as our paint melts under the extreme equator lines....
remember the secret is to keep your pad flat...at all times
thanks to the brilliant magic portion of Doc G
it has been another wonderful time of lesson & knowing so much new friends
Our little effort in sharing our knowledge to trains others in car detailing..... thanks to Master seech who came & taught us
Looks like you have a great class going on there. Super work on the sanding marks, looks perfect.
:wave: KC's, looks like you are helping out a new generation of detailers :)
Very nice KC! Thank you for sharing with the rest of us.
Learn - Do - Teach..... Awesome - :props:
Awesome! May I come to visit? It is getting TOO cold here! :D
Edit To Add: Actually, I plan to be in Singapore (two days), KL (a day or two) and Bali (three or four days) in February...
Thanks Finemess, for your kind words...yes indeed was wonderful & far amazing to have my buddy seech coming along side to teach
Thank you sir
The least I could do when I am still around before I kick the bucket
I know I cant bring along my ferrari or masserati or bugati when i say bye bye...so I decided to share with the rest....my ferrari now...by training & equipping others
Detailing is fun
Thanks Cee Dog, for your constant cheers along the way..It my honour to know u & sharing with u now...Thank you my friend
Thanks Bobby....its fun when u teach....others wise
ALL WORK NO PLAY MAKES JACK A DULL BOY
Very nice to see you teaching the craft.
Thanks Tw33k2514, for your kind words
sure same guy, pls do :xyxthumbs:
