Single Stage Paint Advice
mdrees
Single Stage Paint Advice - I'll be doing a polish and seal on a 1950's Plymouth 2 door car (non-original white single stage paint). I took multiple paint thickness readings which were all over the place. The thinnest area was the roof an fender tops (2.5-3.5 MILS). The paint had light oxidation but was still somewhat shiny. Was considering doing a gentle (white or black soft pad) with HD Speed AIO. I did a small test section and it looked really
good. I'm a little worried about the thin areas - has anyone worked on older single stage paint with HD Speed? Definitely don't want to burn through paint on a car of this size. Thanks in advance for your advice.
