I originally posted this to Reddit, but the only response I got was Mike's insanely helpful guide to single stage paint. I want to understand why my single stage paint got lighter after correcting it.
I'm learning to paint correct on my 98 Lexus ES300. It's classic green pearl, which is single stage. I've done the hood, roof and trunk, all of which are a the result 10 year old cheap Maaco job. Up until today, I was only doing a single pass (once left to right, once up and down), and as a result wondering why I still had a decent amount of scratches despite compounding and polishing. I found Mike's video tutorial on how to paint correct, and saw that he was doing 8 passes.
My first test spots were on the hood, the paint got lighter after I stepped up the aggressiveness. I decided the best strategy was to do one compounding and one polishing pass and moved on to trunk and roof. After learning that I could do more passes, I tested out the roof (which I had already compounded + polished 1 pass each) by polishing with 4 more passes to see the difference. I got the results I was looking for, and went back to experiment with the hood.
This time, I did three passes while compounding, and 3 passes polishing. This definitely removed more scratches, but also removed the much of the dark green color, causing the area to look dull. You can see the results below, the area in the top right is my original test spot. Apologies if the image isn't clear, it's my first time posting. I've got photos up on imgur as well if that helps, the link is https://imgur.com/a/YBPuzr2.
I understand how 2 stage paint jobs work and have tried correcting panels on another car (albeit using 2 total passes each), but I am confused as to why the paint got lighter when I feel like I didn't even cut through that much paint. I thought that single stage paint was paint + clear coat in one substance, and that unless you had metallic paint which has flakes in it, the substance should have a consistent amount of paint and clear coat. Does pearl single stage work differently than normal? Or is this a function of how the area was repainted, like a lighter green coat laid down and then a darker green on top?
I'm not too bummed about it, as it isn't original paint and I am perfectly fine experimenting with it, though seeing how bad it looks on screen in wish I could fix it.
