Small specks in paint?
StubbornGoat
So,
I opened up my new GG6” and got to work on the hood of my daughters Altima
Washed first
Then hit it with the Meguiars claybar
Then Griots compound
Followed by Griots AIO polish/wax
Finished up with Meguiars ultimate paste wax.
Came out quite good, swirls and light scratches are gone just some paint chips and a deep scratch left,
Except the hood has small specks that look to be in the paint.
What is it?
Where did I go wrong?
(Tried to take a picture for reference but with my phone all I got was a mirror image of me taking the picture)
Look up “solvent pop”.
It’s not your fault. I don’t think you could cause it to happen by polishing but polishing may reveal it more.
Possibly the hood has been repainted?
If if it is then it’s not your fault. I don’t think you could cause it to happen by polishing but polishing may reveal it more.
The hood has not been repainted we got the car new in 2013.
Googling solvent pop now......
If it's factory paint it's definitely not solvent pop. I've owned every genreation of Altima since they came out and my daughter currently has a 2016.
Really need to see pics to diagnose. Try taking them in a garage or early in am out of sun. What color is it?
Took car out of garage and was able to pick this up the spots in the photo.
The car is black.
I was able to get this picture in the garage.
(Man does the camera really show those paint chips. They don’t stand out nearly that bad in person :(
Can you feel them? Could it be some kind of chemical that compromised the clear?
Don't be to sure on the "original paint". Lots of new cars get damaged in transit and they will respray and sell as new. That does look like solvent pop, but hard to tell, I've had what looked to be the same specs on my repainted black hood. Most did disappear for me with a compound/polish.
I don’t fill them with me bare hand but when I pass a microfiber towel over the hood I can fill that there is some thing going on.
When I get really close to it, it looks like really small pitting maybe?
It could also be a start to clear coat failure. I'd have someone take measurements. Hopefully you didn't compound to much...
If I spray and wipe the hood with detail spray (Chemical Guys Synthetic Quick Detailer) I will get trailing streaks from the spots.
The reason I ask is because it seems localized to one area which makes me wonder if something splattered on the hood and ate into the clear.
^That my thought after seeing the pics. Possibly some lovey chemical that someone accidentally spattered onto the hood.
That, or maybe bug droppings/secretions but then it probably would not be so localized.?
Maybe try rubbing it a little more with the AIO to see if it pulls anymore out.
It looks alot like the specs I was dealing with on that black Denali. It was terrifying at 1st glance because it looked like clearcoat failure.
In my case they began to go away with the claybar, and fully went away with a dedicated polish and just a finishing pad.
My 1st thought is maybe the AIO didn’t play well with the sealant [Ultimate Paste Wax]
Or maybe the AIO itself finished off poorly.
It looks a lot like your pic Eldorado2K,
but the specks appear white in the picture but actually don't seem to have any color to them in person. they are quite clear-ish.
The ones in my pic appeared like tiny bubbling like the way it looks when the clearcoat is starting to fail. I’m glad I remained calm and didn’t panic, because that was a brand new 2018 Denali! Lol.
When did you notice them? When you were all done? If so it’s too bad otherwise you may have been able to pinpoint when they became visable.
Could it be that when you did the AIO step some residue got splattered to the already AIO polished area? Then it dried there and sealed in with the wax step. Try to QD wipe a small test spot or a waterless wash product and see if it's gets off. A panel wipe product could solve it if it's not coming off. But would need to be waxed again if you do. Otherwise a finishing polish on a finishing pad and see what that will do and if the spots remains I think it's a paint problem.
What exactly where the compound and pad combo used on the first step?
And how many passes per sections did you do?
How was the defects when you started?
I never noticed them until i was finished, but the hood was in pretty bad shape when I started, there was stuff all over this thing.
As for as products
It was what ever drive thru car wash my wife took it to.
Meguiars off the shelf clay bar with CG synthetic detail spray as lube ( it seemed to work better than the Meguiars quick detail that came with the kit.
Griots complete compound
Griots one step sealent
Chemical guys Synthetic detail spray.
I ordered the aggressive Meguiars clay bar to give that a shot. Just waiting for that to come in.
I'm going to check my other black car to see if there are similar spots/specks on it. It has never been properly detailed before that i know of.
I had something similar happen to me when applying WGDGPS 3.0. At some point during my first of 2 coats I managed to get some splatter from the DA which I failed to spot during buffing. I proceeded to apply the second coat, also without noticing. It was only during the buffing of the 2nd coat that I noticed yellow specks, which at this point had been effectively "sealed" under the second coat. I just clayed them out and resealed and all was right with the world again.
Sent from my SM-G955U using Autogeekonline mobile app
