Smaller Pump Sprayers
BLM1
Looking for a smaller pump sprayer, such as an IK multi Pro 2 just for rinsing wheels and tires after scrubbing with wheel and tire cleaner when not using a hose. Also of course to rinse off same prior to applying the wheel and tire cleaners. Not looking for a foamer.
The obvious choices are the IK or the Marolex. I am under the assumption that the Marolex produces better pressure than the IK. That being said is the IK sufficient for this task? Or is there something else that is better suited for this task. Again only want something when doing rinse less washes and don’t want to drag out the hose for just wheels and tires.
If you only want to rinse tires/wheels with plain water I would go with an inexpensive 2 gallon yard sprayer as it can hold way more liquid than an IK 2 and it would cost a third what the IK would
I doubt an IK 2 would pre-rinse and then post-rinse a set of tires without a refill or two and you would be pumping it up multiple times
YMMV
Yah you are right. Wouldn’t mind the pumping but having to refill would definitely be a pain.
YMMV
I completely agree. I have a 1-gallon Chapin garden sprayer that I bought at Home Depot for $20. I use it for exactly that same purpose of rinsing off wheels and tires when I don't have access to a hose. It works great and holds a lot more water than my smaller iK sprayer. You definitely want enough liquid in the sprayer to spray all 4 wheels. It would be really inconvenient to have to refill the iK sprayer in the middle of the job.
I use that same sprayer for RW pre rinse
Simple and cheap
Simple and cheap
I have the same sprayer as well. I bought it for doing Rinseless washes. One gallon is enough for a pre-rinse with plenty of solution left for rinsing off tires and wheels.
I just bought an IK multi 2 pro which is 50oz for $38 after tax (free shipping). Seems like a fair enough deal for one of the best pump sprayers around. I had, previously, bought a $15 harrison garden (typical type of sprayer) one and it just wasn't very good. I doubt anything under $30 or so is going to be quality or have a great spray pattern etc.
