So I bought the 3 and 6 inch Griot's polishers.
gsmarquis
Member
I have been using the cheap 50$ DA we all know of. I went ahead and bought the Griot's 3 and 6 inch polishers after using the $50 dollar HF and enjoying the job. I plan on using a 5" vented backing plate with 5.5" lake country thin pro pads. All I know as far as polishes is the cg v line. I have a ton of the product left. From all the things I am reading it's subpar polish. Bought it before finding autogeek. Should I abandon 50$ worth of vline and go for the 105/205 combo?
No.
Abandon the v line and get Griot's creams. You'll be as impressed with these as much as your new machines. :dblthumb2:
I'd use up the CG stuff on beater cars, and integrate Meguiar's Ultimate line.
Get both Griots Boss Correcting Creams but stick with your plan of M205. IMO it’s way better than the Perfecting Cream.
I would use the CG V stuff on headlights and beater cars. You can always use V32 and V34 and follow up with a good finishing polish like Menz 3500. Menzerma products are better in every way.
Yeah CG stuff has no bite
Here's good ones to get
In no specific order
Angelwax ressurection and redemption
The last Cut by Jace
GYEON compound + and Polish
3D AAT stuff
Shine supply
Sonax max cut; EX, and perfect finish
Griot Boss cremes
As for GG3..get the 2 in conversion..or perhaps DA 2 rotary adapter and 1in rotary BP
The two most common terms I "type" and "talk" are,
  1. Abrasive technology
  2. Touch
Abrasive technology
When it comes to working on paint the MOST important factor is the abrasive technology, NOT the person, or the tool or the pad. Some companies have GREAT abrasive technology and others have room to improve. You have some good suggestions so far in this thread.
Touch
Answering questions professionally for 16 years now in the forum world, a normal pattern is first a person joins and asks
How to remove swirls?
That is where I talk about abrasive technology amongst other topics.
THEN after they get the paint on their car looking good they ask,
How to prevent swirls and scratches?
And that where I talk about the word touch. That is, anything and everything that "touches" the paint has to be of the highest quality you can obtain and then of course use good technique. I'm mostly talking about,
  • Washing
  • Drying
  • Wiping
These are the things you do to the paint after correcting, polishing and sealing.
Make sense?
So yeah, get some new abrasive technology.
Are you thinking of abandoning the CG stuff before even trying it out?
Maybe give it t try first and see if it works for you. A lot of hate on this site for CG but almost all of the stuff I've tried from them has been pretty good.
In my systems engineering world there have been adages,
"Nobody ever got fired for buying IBM" - old days
"Nobody ever got fired for buying Cisco" - dotcom days
"Nobody ever got fired for buying Okta" - current single sign-on framework
In the detailing world,
"Nobody ever got fired for using M105/M205"
If you try Menzerna polishes it is more than pretty good.
So I have only polished one car and it was GM Black. It came out great. I want to keep all of my cars in as close to perfect as I can. I dont know if I can say I am used to diminishing abrasive tech or not having done one car. What can I expect from non DAT polishes?
I have no problem throwing down money on quality products and machines. If the polish is $60 so be it. I will buy another machine like a mille or something but I want a few years under belt. I would like to "graduate" to a $500 machine so I can give my lower machines to a friend and bring another into the scene. I feel that getting the hands on experience with tools of lower capability will give me that much more appreciation of the flagship tool.
Its kinda like winning the race with a 10yr old civic that I bought mowing lawns vs winning the race with a new zl1 that a teenager got from daddy.
Get yourself some nice polishes that perform well and are relatively easy to use. In saying that M205 is nice. M105 is not my favorite compound. Short working time, hard wipe off and dusting were the biggest complaints I had about them. It's not a bad compound but there are better that perform just as good if not better.
GYEON Polish
To the op these are good. Sonax has a good line of polishes and I would recommend them as well. I would even toss cut & finish into the mix if one is looking for a one step compounding polish. User friendly and they don't dust other than perfect finish that dusts a little at least for me.
I have only used the Gyeon Polish and it is nice to work with. Not as much cut as M205 but finishes a bit better.
So Autogeek store is going to be a problem for me..... Everytime I get a discount email I purchase something. This is going to be worse than my Am***n problem was. Lol.
So I went ahead and ordered Griot's Boss polishes/compounds as well as Carpro Essence with the gloss pads. I will use the lake country thin pros with the Boss stuff and final with essence on Carpro gloss pads. I don't know what's so special about the specific gloss pad, they have about same feel as the red final pads from my other pad companies.
I will be doing my wifes Durango next with the LC thinpro pads and BOSS creams finishing with essence. Cant decide if I want to UK 3.0 coat it or just a sealer and wax topper.
I did buy a PTG. The Durango paint is much thicker than my Suburban was. Durango avg is 180-214um, Suburban avg is 125-130um. Both were bought new. I have never corrected the Durango but the Suburban got a light polish for the UK coating using white hex pads and v38.
I also took some readings under my badging when I changed to black badges on the Suburban, 130um.
Thanks Autogeek, I'm all in and going broke.
Yessir, welcome to your newest addiction / obsession!! Might wear ya out but won’t kill ya. And your vehicles will look good!
gsmarquis.. if you haven't already, i would recommend picking up the 2" conversion kit for the GG3. it will turn it into a scalpel aka the "Mini BOSS" to match your "LiL BOSS" aka GG6 ;)
Griots Garage 2 inch BOSS Foam and Microfiber Pads
info at the 11:40 mark in the video below...
