pheerix
- Apr 18, 2015
- 994
http://ep.yimg.com/ay/autogeek/meguiars-car-wash-plus-coming-soon-1.gif
Meguiars Car Wash Plus+
A waterless wash...lotion?
I can't see using it with a wash mitt, what do you do when the mitt is full of dirt. Maybe using multiple mf towels like a waterless wash?
This sounds like a wash that would need polishing/waxing after?
Great point. There are many variables, but in general one application will not completely remove for example a polymer based wax like our Ultimate Wax, but it will knock it down pretty well, so yes, it would be recommended to follow with one of our protectants after an application.
Not only does it sound a little harsh. How often do you have to rinse your wash mitt. Before every application? or does it depend on the amount of dirt on the vehicle? After applying do you have to rinse vehicle?
Sorry for showing how far i am behind. Just trying to grasp all the new products, and technology.
Hi J.A, this is used like a normal car wash except without diluting the product with water in a bucket. For best results we would recommend rinsing your wash mitt just the same as when using a standard two bucket wash method. We would say that most users rinse their wash mitt prior to needing to retrieve more suds, so the same goes for Car Wash Plus +, when more product is needed on the wash mitt, rinse out with the hose first! Yes this product needs to be rinsed off the vehicle, just like a traditional car wash, it is not a water-less or rinse-less product.
Short shelf life I'm predicting...
applying it straight to the mitt instead of wash bucket where it will be diluted will probably affect the outcome since it says it will polish away light scuffs. this looks like a product that would work well as part of the paint decontamination process before polishing..
They spent the R&D time and money to make this but yet discontinue D114, LOL!
I got this and have tried it
Works well at getting scratches out from under door handles when you scrub it like you would manually compounding/polishing.
It does take out scuffs and tar,bugs well
I did 1 strip of product across MF wash mitt..Very foamy/lubricy...Did half car no dirty clinging onto mitt tenticals..
I was curious if it would strip an old spray sealant with the abraisives....Again scrubbed hard doing cross hatch pattern as once would by correcting paint by hand..
Rinsed off then sprayed again, beading gone...Next day it rained panel was beaded up...Wiped dry and sprayed with hose beaded up..
I'd be caution on soft dark paint..But so far it worked with out scratching for me when washing as one would normally.
