Is 70/30 mix MF the softest available?
That chart recommends 700 GSM towels for waterless washing. Those work great for me. I also have some 800 GSM towels that work well. My thinking is the more liquid they hold, the better. The 800s hold a ton of water. I also like using the lightest possible color so I can see how much dirt is being picked up.super soft drying towel to remove dirt....
The Adams site lists the MF GSM specs but not the polyester/polyamide specs, any idea what they are?I really like the Adams double soft towels... the single soft and triple soft are amazing as well.
Thanks, I'm aware GSM is unrelated to softness, which brings me back to my original question, does anyone know what the softest MF available is. From what I can tell a 70/30 mix is the softest I've seen with any of the MF manufacturers.GSM and softness are not related. GSM is a measure of density, not softness of the fibers the towel is constructed from.
Appreciate the info, I actually started the clear plastic thread because I recently replaced the windshield on a motorcycle in my collection and ultimately would like to keep it micro-swirl free. From threads I've read here I guess even the softest MF can cause micro-swirling if used dry. If you had to pick your favorite MF for maximum softness in your opinion which would that be?
I'm I correct then in saying there are no towels than can be rubbed on a dry soft surface without creating swirls?I would use a low/no.no nap MF for that. Either the TRC Glass and or even something like the Large CQ Suedes which are quite nice. I have had terrible luck with the Boa's
