Hello, I am very glad to be on these forums! They are excellent.
I've learned to polish a bit in the past year with my DA and have had decent results. I have a good selection of foam pads and a good finishing polish. The compound I have been using (UC) is almost out so I'm looking to buy a new one.
I've tried using UC with foam pads on a car with very hard paint (single stage white I believe) and while it has improved the finish, the swirls and scratches are still there. When I was working on the car, I believe I was not taking my time and doing it a bit too fast. I was applying plenty of downward pressure on the machine (maybe a bit too much) but it didn't really help with the paint defects. I will try to work slower and see how that goes.
I'm looking to get some microfiber pads to see how they do. I'm also going to get a new compound as well. Right now, I'm looking at HD Cut since it seems to have good results. I'm just wondering if this is the right approach. The other option is to get more foam pads with a heavier cut. But I just want to see how the MF pads do.
How many MF pads does one generally need to do a mid size car? Can 2 be enough?
I've read that blowing compressed air generally cleans them. Also, how does one clean them after polishing? Similar to foam pads or is there another way?
I have a pad cleaner but I'm not sure if MF pads can be cleaned the same way.
I would appreciate any help.
