some questions about Wolf's Chemicals products
2shiny
Hey all,
So I have some questions about some WC products...
1) is the Nano Quick detailer "reparation" a spray sealant /QD and comparable to CG V7 / Reload ,...
As I really miss a spray sealant in their line, or would the "Quickie" be the only spray wax?
2) Would the body wrap be labelled as a sealant or a coating, as I read it is better applied by make-up cotons then by mf or foam applicator
3) You seem to have 2 AIO, the Shine & Seal and the Caranuba Glaze.
is there any difference other then S&S is sealant and CG is Caranuba?
4) Is the Glass coating any good? as I see it's more expensive the some other, well knows brands like Carpro / Gtechniq / Nanolex...
5) has anyone used the compound " The Equalizer" with a DA on ceramic clearcoats? how were the results?
thx
Not a fan of there products I have used the window coating and took 3 coats to even work right. Its a pain to put on also.
I can only help you with question 2..it's a sealant, but why not use Hard Body, which is a glass coating and much better durability. I apply it with a DA and a red H2o pad on speed 3.
ow, so the hard body is quit easy to apply? might have a look into that one. thx
won't be going for the glass coating then. thanks
