DaC
- Aug 11, 2011
- 855
- Guys, after using the autoscrub pad I can see the paint beading, does this happens to you ? I'm using ONR as QD lube.
- After using the autoscrub (only) on windshields I can see rain drops flying off the windshield from about 45+mph, like if I had used something like Aquapel.... do you see this effect too ?
- Do the pad needs to rotate in order to the autoscrub to work properly ?
