Dr Oldz
- Aug 31, 2010
- 4,462
So I have had this about a month and wanted to share some quick thoughts.
So let’s get the most popular question out of the way: Battery Life! Kit comes with two batteries. To date I HAVE NOT been able to use a full battery before the other charged FULLY! Which means you can use this continuously on only 2 batteries. Remember you typically stop to wipe product off or inspect your work.
My first take was that the switch was a bit hard to use. There was a bit of a learning curve but now I appreciate its operation. It’s nice to be able to throttle the machine in certain instances.
Secondly, it has a ton of power. Has no problem rotating the 12mm adaptor with a 3inch pad. With the rotary adapter and a one inch pad, you can NOT stop it even on speed 1.
The one inch sticky disc with the 3mm throw is simply amazing for spot sanding scratches. While the 3mm is absolutely useless for polishing, it is intended for sanding. Personally I prefer to chase scratches by sanding rather than compounding. It is much easier on the clear and much cooler. After sanding, bang... use the quick connect, put the 12mm with a 3inch pad or the one inch rotary adapter on and polish to perfection. I love it for this reason alone.
I find myself using this tool so much now. Bumpers, pillars, door jambs, glass and any tight space. I love it for headliners. I often use a DA with a MF pad and a dry foam on a slow speed to clean headliners. Not looking for pad rotation in this instance but rather a light agitation. Being cord free, compact and light really makes this process a dream for me.
I did a classic that had a metal dash and glove box and this was the right tool to perform the polishing in that area!!
I’m very happy with this machine and keep finding new uses for it. Glad I bought and would suggest it to anyone looking for such a machine.
Now to get to the cons. There are no cons with the machine itself but rather the attachments. I would love to see a 2 and 3 inch backing plate for rotary mode. While the 12mm attachment provides plenty of power, sometimes I prefer the precision of a rotary without the ghosting footprint associated with a DA! This machine has the power to handle those easily.
I would also like to see an extension for rotary mode.
Hopefully Flex can supply those items in the future.
Another thing that is confusing is mine is a 12 volt. I have seen 10.8 volt models. I think they are the same thing and just labeled to sound better but I would like to hear some clarification from Flex on this as some chargers are labeled for 10.8 and 18 volt usage with no mention of 12 volt.
Thanks for reading and feel free to comment.
Jim
Jim
