SON1C Synopsis 10 - Chemical Guys - Lightning Fast Carpet Clean and Stain Remover
SON1C
autogeek_2213_59216735
First impressions .. dilutes 20:1 .. wow! That is a high dilution rate aka what I like to see!
Before and afters on these 10 year old stains in this vehicle
And another spot
Before and after stains removed on this vehicle
Well the pictures speak for themselves, I agitate after letting it sit for 1-2 minutes with
autogeek_2210_158681649
Carrand Deluxe Interior Brush, carpet scrub brush, upholstery brush, rug brush, carpet cleaner brush
These interior Carrand brushes are awesome, agitate easily and quickly, after use they are easily cleaned with a wash and slight agitation. :xyxthumbs:
After soak - agitation - I follow with a MF cleaning to help pull the rest of the stain out. The results are great for in my opinion and for under 20 dollars for products and tools, what is not to like?
This carpet cleaner is fantastic it does exactly what it claims to do, it removes stains and quickly, highly concentrated, foaming but not too much which is a plus for me, and a little goes a long way, definitely a quality product and worth giving a shot!
Chemical Guys Lightning Fast Carpet Clean & Stain Remover 16 oz.
Very nice review. Thanks for sharing. This looks like it will work better than Folex. Now you said it can dilute up to 20:1 but did you actually dilute it that much in your review?
Good review I am gonna pick some up on my next order
You won't be disappointed! and thank you
Nice review. That brush looks awesome.
Thanks for viewing! and yes it is I even wrote a little more about it here http://www.autogeekonline.net/forum...ynopsis-11-carrand-deluxe-interior-brush.html
Thanks for viewing :xyxthumbs: I have not used folex however I would place my bet on this product, yes I have only used it diluted at 20:1 which is what all the review pictures are from. IIRC it can be used at higher concentrations if 20:1 isn't getting the job done but I imagine just a second application of 20:1 would do the trick.
Great review! I was wondering if I should get this since I have been using CG's Fabric Clean for the last couple months with good results. Maybe I'll pick up a bottle of this one day to test out.
Thanks :xyxthumbs: yeah I would definitely give this product a shot, how are you liking fabric clean?
Thanks for the excellent review. I have the product and love it also.
It performs exactly as it says and i love it.Ive never tried Folex but i havent come across anything that Fabric Clean couldnt take care of yet. Also works really well at 10:1 dilution.
Hi, what a really helpful review. I was given this link on another thread to check out, and I'm glad I did.
Can this be used with Folex, or is it a replacement to a pre-treater? Also, can this be used in the solution tank of a carpet extractor? Thanks! :)
Those are all great questions, however I'm not 100% sure so I wouldn't be able to give you exact advice, I'd give ag or cg a quick call about this :xyxthumbs:
CG - Fabric Clean
The description for Fabric Clean says:
* works well with carpet cleaning machines.
Not sure if that means it could be put into an extractor. The CG videos show this product being sprayed onto the carpet then agitated.
CG - Lightning Fast
In the description for Lightning Fast it does mention "...or it can even be put into all leading extractor machines for superior results"
It would be good to see Folex up against both CG products. In a CG video they spray the Lightning Fast first and wait two minutes then use the Fabric Clean to agitate the carpet.
It looks like you could use the CG Nonsense cleaner too, dilution ratio is 20:1
bump for this product being on bogo!
For semi dirty mats you can use the Lightning Fast and if the mats are very dirty the Fabric Clean should be used as well. Fabric Clean foams up really well.
From the CG videos and reading the product descriptions the order to use their three products in would be:
CG Nonsense - Light Cleaner
CG Lightning Fast - Mild Cleaner
CG Fabric Clean - Strong Cleaner (Also contains odor eliminator)
Keep in mind all the above products could be diluted less to make them work stronger. As mentioned above the Lightning Fast & Fabric work great together on dirty mats.
I just bought this on bogo, definitely excited to try it! Thanks for the nice review.
Ordered them too on BOGO even before seeing this thread. Glad they are good prodcts.
