SONAX Leather Foam Leather Cleaner & Conditioner
larryt1026
Hello,
Was just wondering if this is water based or oil based? Wanted to make sure I'm not using oil based on my leather. Thanks.
not sure if this helps or you even saw it :) I know it doesn't answer your question directly...
SONAX Leather Foam contains modified Beeswax, one of the best known ingredients for conditioning leather. Beeswax leaves leather soft without a greasy residue - more like the texture of new leather. Sink into a soft leather driver's seat that looks and feels the way leather was meant to feel.
SONAX Leather Foam contains no dyes, harsh chemicals or silicone, making this product ideal for any color leather. The foam safely removes stains without removing color from vat-dyed or surface-dyed leathers.
This foaming leather cleaner and conditioner lifts and removes soil without drying out the leather’s natural fibers. The low moisture foam doesn’t soak the leather; it safely lifts dirt and oils to the surface of the leather where they can be easily wiped away. Leather that becomes very wet and then dries loses its softness.
