Sonax Profiline Perfect Finish...
malypb
Such a little curiosity.
The doors I did (cutting) with Meguiar's DA Microfiber Correction System - D300, MF cutting pad, DAS-6 PRO.
And now a small comparison of finish.
The right side is Meguiar's Finishing Wax (D301) on MF finishing pad and DAS-6 PRO after 5 months and only two very delicate, cautious washes.
The left side is Sonax Profiline Perfect Finish on HexLogic white pad and Flex PE14-2-150 (rotary).
It's 12 years old Opel Astra Coupe Bertone with normal or light hard paint.
http://www.autogeekonline.net/forum/show-n-shine/66360-opel-astra-coupe-bertone-second-youth.html
And I find the Sonax polishes extremely easy to remove and have hence, become my "go to" product line. A picture is worth a thousand words.
I would lend results to polishing oils and polymers rather than to abrasives, or lack thereof.
And yourself, please?
I wonder if the new Megs d302 would finish that right side a little closer to the clarity of the Sonax (see Mike's new thread regarding the Megs MF system).
The OP used direct drive/foam with the Sonax.
I expected to see the haze with the DA worked 300/MF on everyday hard paint.
Here's the kicker in my book. Foam on direct drive gives a better finish than MF on DA when using the same product in most instances ~ even when results are hidden by the oils/polymers.
I need to go back and read the thread to see if the OP had any conclusions or preferences.
I wiped down the panel twice (or even more) with CarPro Eraser, lots of it. I think that all oils have been washed away.
use an IPA mixture to wipe it down a few times. Then look at it and that will be your true clean paint with no oils.
This is the car after an exhaustive detail process.
[ame=http://www.youtube.com/watch?v=XZyt7FGHPeU]Opel Astra Coupe - Second Youth, the final result - YouTube[/video]
5 months and two delicate washes later you do basically a 50/50 on the door with the Sonax PF/rotary and the picture is your result?
I'm stuck like Chuck :o
