Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 6
SONAX Wheel Cleaner Plus vs Cragar SS Chrome Wheels
My brother-in-law recently purchased this very rare 1970 Ford Torino GT Convertible and we spent some time detailing it inside and out for a new series of car detailing articles.
For this article we'll address the wheels and tires.
Tool Showcase
Most guys know me as a machine guy, that is if I can do it by machine then that's the the way I do it. When it comes to cleaning tires I prefer to machine scrub the tires clean instead of hand scrubbing but you have to use some COMMON SENSE so you don't get hurt. After machine scrubbing the tires remove the tool and the power cord from the area before rinsing. Simple and safe.
Note: Whenever I do any type of wet work with a DA Polisher, for example machine scrubbing or machine wet sanding, I always choose the Porter Cable because it's double insulated for safety. I also ALWAYS plug into a GFI power outlet which we have here at the Autogeek Show Car Garage. If you don't have GFI power outlets at your shop or house then you can use a portable GFI plug-in. See my article here,
Safety First - Always plug-in to a GFI or Ground Fault Interrupter
Product Showcase
For machine scrubbing I'm using the Porter Cable 7424XP and a Cyclo Gray Ultra Soft Upholstery Brush. The bristles on this brush are flagged so they won't scratch smooth sidewall tires but they still do a great job of cleaning off all tire dressings as wells as tire blooming and rubber oxidation. They also restore a clean bright white appearance to the lettering.
For a tire cleaner I'm using SONAX Multi Star All Purpose Cleaner and for a wheel cleaner I'm using SONAX Wheel Cleaner PLUS.
Dirty, grungy tires. I don't know what type of dressing was used on these tires in the past but it's about to be removed.
First I spray on the Multi Star APC
Here you can see the flagging of the bristle which makes them safe enough to machine scrub vinyl and leather seats.
Machine scrubbing tires...
Time to clean the classic Cragar chrome wheels. First I spray on the SONAX Wheel Cleaner PLUS. As it comes into contact with brake dust it will dissolve it and you'll see this as a red bleeding effect on the wheel.
Wheel Woolies Wheel Brush
My favorite brush for cleaning wheels.
Then blast with water....
Next up.... dressing the tires...
Tool Showcase
Product Showcase
