SONAX Windshield Sponge
claycourter01
Sonax always has good products but I'm a little confused by this one. Is it intended to be used dry on both sides, or with a spray cleaner on the first side and then the second side dries? Or is a spray cleaner used with both sides and then a separate towel is used to dry? Any information or suggestions welcome; thanks.
No idea, that description makes no sense, sounds like it may be a poor translation from the German.
My Dad used to have a similar sponge in his drivers side door pocket in case the inside of the windshield fogged up. I'm thinking this Sonax sponge ins something similar?
thanks-- I had the impression that it may be an inside windshield procedure, but I would not have thought that fogging was a sufficiently frequent an issue to require a specific sponge.
So if this is meant for the inside, then used completely dry or with a liquid cleaner?
Re-reading it in that context, it sounds like something you use dry while you are driving if your windshield fogs up, you wipe it with the yellow side and then the blue.
OK thanks! I had purchased one of these assuming it had a more general application to outside as well as inside windshield glass cleaning, but it is looking to be a more specialized product, if your interpretation is correct.
