South Florida Headlight Restoration by Sully’s Detailing
sullysdetailing
Safe night driving requires a clear vision. Our Headlight Restoration Service will restore the clarity of the headlight lens, making sure you have a clear vision of what’s ahead.
Benefits of Sully’s Headlight Restoration:
  • Increase Safety
  • Increases resale value
  • Increases visibility
  • Improves appearance of your vehicle
  • Save hundreds of dollars on costly replacement headlights (average cost of new headlights is $250 each without installation)
Before:
After:
Before:
After:
Before:
After:
Thank you, I used a 3'' air DA and the meguiars sanding kit then coated the lights with Helmsman Spar Urethane
Hey Shawn,
Great job on those headlights. Have a question....what do you use to apply the Spar Urethane onto the headlights?
Cintoman
LOL at all of them being Nissan's and them mostly likely being less then five years old
Great job, expectially the Infiniti M sedan.
Thanks guys. To apply the spar I use those heavy duty blue shop paper towels. It works great. When you apply it, it looks streaky at first but it will level out. If you try to wipe the area again you will mess it up and have to start all over
Sent from my PC36100 using Tapatalk
good job sully
