Pats300zx
Active member
- Mar 7, 2006
- 5,331
- 20
This is a review of the Speed Master Swirl Finder Detail Light. For the purposes of this review I will be comparing it to my current swirl finder light which is the Astro 50SL Pneumatic Sunlight. Both lights are identical in shape and design and both have many similar and unique features that are essential for detailing. Both lights feature a magnetic base and adjustable neck making the light usable in many different situations related to car care. I feel these lights are a must for any type of paint correction, coating application, window cleaning or interior work. The new Speed Master Swirl Finder Detailing Light does have a few features not previously found on the Astro 50SL Pneumatic Sunlight.
Astro 50SL Pneumatic Sunlight Specifications
Speed Master Swirl Finder Detail Light Specifications:
Cost: $114.99
Thoughts and observations:
Both the Speed Master Swirl Finder Detailing Light and the Astro 50SL Pneumatic Sunlight are excellent lights. The Speed Master Swirl Finder Detailing Light does cost substantially more money but does offer several features not found on the Astro 50SL. For someone looking for a greater range of light kelvin and a slightly higher lumen output the Speed Master Swirl Finder Detailing Light might be worth the added expense.
Pictures:
Speed Master Swirl Finder Detail Light on left-Astro 50SL on right. Both are identical in design.
Both lights come with a charging base and a light indicator on the front showing the charge level.
I tried to capture and compare the various settings and light output of the lights side by side.
- The Speed Master Swirl Finder Detailing Light has three light settings that include 2700K, 4500K, and 6500K. The Astro 50SL Pneumatic Sunlight only has two settings.
- The Speed Master Swirl Finder Detailing Light is rated at 500 lumens and the Astro 50SL Pneumatic Sunlight is rated at 400 lumens.
- The Speed Master Swirl Finder Detailing Light has an “eco mode” which shuts the light after 5 minutes.
- The Speed Master Swirl Finder Detailing Light is rated at 2.5 hour use time while the Astro 50SL Pneumatic Sunlight is rated at 3-4 hours.
- Spots color differences and paint imperfections like only a high CRI color match light can
- 400 lumens
- Easily removable and cleanable lens
- Collapsible hook 360 degree rotating hook
- 180 degree folding magnetic base
- Impact resistant
- Working at 5500-6000K, it exactly replicates the color temperature of the mid-day Sun while achieving a high CRI of 95 - guaranteeing an accurate representation of surface colors and imperfections.
- Spots color differences and paint imperfections like only a high CRI color match light can.
- IP65 water and dust proof.
- 100% solid aluminum construction. LED Max Power Color Temperature Light Output 400 Lumens 4100K Water Proof Battery Life 5 Watts IP65 3~4 hrs Li-ion Rechargeable
- Battery Charge time 3.7V/2600 mAh Battery life is 3-4 hours
- Cost: $64.50
- 500 lumens
- 180-degree adjustable handle, allowing for versatility to any space.
- Magnet on the back and bottom of the device,
Boosts LED 500 lumens and contains three levels of lighting power (including of levels of CCT (correlated color temperature) in kelvin are: 2700K, 4500K and 6500K. - Super bright with a high CRI (color rendering index) of 96+.
- Can run for two hours and thirty minutes on a single charge and as an automated system that will change to ECO mode after using at ‘high mode’ for five minutes.
Cost: $114.99
Pictures:
