Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 8
Speed Settings for the Flex 3401
The below are recommended ranges for using the Flex 3401 Forced Rotation Dual Action Polisher. The tool is actually easier to control and move over the paint at higher speed settings versus lower speed settings. Keep this in mind if you're brand new to using the Flex 3401 and you turn it on for the first time using a slow speed setting.
Get a feel for the tool when you first turn it on using a slow speed setting and then use your thumb to turn up the speed as your comfort level increases.
When first starting out, practice on a large, flat horizontal panel like the hood or trunk lid of a car.
Show Car Detailing Work
Multiple Step Procedures using Dedicated Products & Pads
5-6 Speed Setting - Heavy Correction Work
With the Flex 3401 and doing any type of correction work, the tool is actually easiest to use and will do the most and fastest correction work on the high speed settings, so for any cutting or correction work use the 5-6 Speed setting.
You can spread your product out using the low speed settings just to get the product spread out over the area you're going to work and preventing slinging of product splatter but once you get the product spread out, use your thumb to move the dial up to the high settings.
4-6 Speed Setting - Polishing Work
For polishing work you can bump the speed down to the 4-5 speed setting or if you're using a polishing pad for correction work then use the 5-6 speed setting.
2-4 Speed Setting - Final or Finish Polishing/Machine Applying Wax
Any time you're doing any final polishing or machine applying a finishing wax or paint sealant then you want to be on the 3-4 setting.
Of course there's little personal preference to all of this but the above are good general ranges for using this tool.
The Variable Speed Dial on the Flex 3401
Production Detailing Work
If you're doing product work and using a one-step cleaner/wax or AIO, (All-in-One), type product you should be in the 4-6 speed range and you'll want the speed and power to aid in doing any correction work.
:xyxthumbs:
:xyxthumbs:
