budman3 said:BTW there is no speed 5.5 on the PC....
killrwheels@autogeek said:that would be the area between the 5 and the 6![]()
budman3 said:I understand that ... but there isn't a click between the two... it goes from 5 right to 6 ... nothing in between it = no 5.5.
Nica said:hahaha that's funny![]()
On the PC I guess it really depends on the product but if you use Optimum prepare to take a little longer to break the polish down. Optimum is good but with a PC it just takes longer for the polish to break down(well at least I've been told). With a rotary the Optimum is really good, this I've seen for my self. XMT on the other hand is really good with the PC, brakes down within 5 to 6 minuits.
Well that's just my opinion.
Nimble said:5-6 min?! That seems like a long time, I get my optimum polishes to breakdown in 3-4 min per panel. I go (on a vertical panel) 1/2" per second, on speed 6, with some good pressure. First pass, up and down with 50% overlapping passes, then left to right for second pass, same speed 6, same hard pressure, then I lightly burnish the vertical surface up and down, speed 6, 1-2" per second. Done. Only 3 passes basically.
