Hello Guys Recentlly purchase the 7424xp with the Spot buff kit after seeing Mike detail off the Lexus . I had for a couple weeks now ,today was my first time using the kit. I found it present a couple of Major Problems. First when you put the backing plate and adapter together the buffer stands almost 6 inches tall and is a little akward to control cause fell like it tip and smack of the car ruin what you are tring to accomplish a great finish. 2nd And the Major Problem which someone could get really hurt because there is so much of a gap between the pad and housing the counter weight is exposed. Today I was holding the buffer like most without the handle and accidently shifted my hand and caught tip of my index finger between the counterweight and housing giving myself a nice little blister. I then took out of the 7424 & put In my Flex Rotary which was safer just a bit cumbersome. I think someone @ AG should take a look at it and Either offer backing plate for a rotary or the one for the D/A when youbuy the kit . I plan on buying plate tommorrow morning and throwning the adater away .
Feed back please
Feed back please
