Hello again. So as I look more into stains and chemicals I am seeing things like Tannin, Alkaline, and Acidic.
Where I am getting lost is what to use on each type. Like for example I was thinking I would use an Alkaline Cleaner on an Acidic based stain. However I am seeing that you want to use a Alkaline Cleaner on an Alkaline stain, I guess the idea with this is that is that it will reactivate the stain due to the same PH and be suspended in the cleaner better and easier to remove.
I thought you wanted to use the opposite of what the stain was.
So with these two different things I am seeing I am not sure what to go by now. The using the same method kinda makes sense due to the reactivating part. But the other opposite method makes sense as it counteracts what is there and breaks it down.
sooo as you can see I am really trying to figure this out.
so far I believe that stuff like dirt, grease, and oil are more on the acidic side and thought I would use a more alkaline chemical to remove them .. but now I am not so sure.
also I am sure that something to do with this is the reason why some APC or Degreasers can set a stain and would like to know more about all of this to avoid setting and being able to get the best results.
any help with this would be great.. Thanks!
