Stained seat belts
mills3
What is the best way to clean really dirty and stained seat belts?
I've tried using a fabric and upholstery cleaner, but nothing seems to work.
I also don't have access to a steam cleaner so that's out.....
I'd try some Folex. It's pretty powerful stuff and can be purchased at Home Depot. Or you could try some All Purpose Cleaner. Or even some diluted LA Totally Awesome.
Cleaners:
•P21S T.A.W. @ 5:1
•C-28 Seat Belt Cleaner and Spot Remover from PRO®.
•Throughly inspect belts for abrasions, cuts, tears, etc.
-Replace where necessary
•Cleaning seat belts requires much caution, and careful cleaning, in order to not compromise the belts' integrity.
-Do not use cleaning products that contain:
Bleach; strong detergents; dyes.
•After you get them clean, be sure to apply some 303 Fabric Protector.
FUNX kinda nailed it for me. I treat mine with Folex and an occasional extractor treatment about once a year. Mine still look new as i keep ahead of them. Reading as you don't have an extractor, my Folex method is to put a clean towel behind them and spray Folex all over them then lightly work my soft bristle brush to agitate. Then i simply blot them dry. A fabric protectant is another good suggestion.
And i agree with FUNX with regard to insuring they remain the "safety" part of safety belts. Look for any wear and tear and don't get too aggressive with your cleaning. I want them to hold my strapped tuchus in if ever needed!
Good luck and any methods recommended here should have them looking great again!
Thanks. I'll have to pick up some folex and see what happens.
If you have a steam cleaner and put brown wrapping paper behind it to draw out the stain if it is sweat or grease /oil based.
Other option is 303 airspace fabric cleaner and spray then let to sit on the belt for a while then scrub it with a firm tooth brush then wipe off and when dry add 303 protectorant
Both are available from autogeek
