These wheels are raw, polished aluminum and brand new, which I then had ceramic coated before installing.
The tire installer sprayed some simple green on them right after installing the tires to check for leaks. I wiped the cleaner off with a rag but didn't use water to really rinse them, thinking that the ceramic coat would act as a barrier between the simple green and the aluminum of the wheel.
I noticed the other day that just ONE of the wheels has this ugly staining on it. I'm going to have the guy who coated my wheels polish the aluminum back to shiny, then put another layer of ceramic coating over it, but I'm curious if you guys know what might have caused this staining. I'm not positive it was the simple green - I just mentioned that because I can't think of what else it might have been. I did use meguires wheel cleaner on them just once, but rinsed it off quickly. And it's odd that all four wheels have been subjected to the same things yet only one has stained.
Thanks in advance!
View attachment 71123View attachment 71124View attachment 71125
Thanks in advance!
