Stainless steel cyber trucks? Any ideas on doing one?
DanaDetailingPros
Where I live, they are everywhere. I'm not a fan, and most of them are painted with a flat finish. I know Dr. Beasley's has a lot for a flat finish. But on a stainless steel, I'm not sure if they will be able to clay. Or will even us the typical 3-in-1? And most of all, can you buff them?
Well, I just got my answer from AI: Detailing a Tesla Cybertruck requires treating the exterior like a giant kitchen sink rather than a traditional car. Because the body is bare 30X stainless steel without a clear coat, standard car waxes will cause splotches, and improper techniques can permanently stain the metal. I figured they wouldn't take the usual routine. I was going to just delete this post after I figured out the answer, but I thought it would be good if anyone came across one.
Decontamination Wash
  • Pre-rinse: Power wash the entire truck with a 40° nozzle tip to safely flush off heavy dirt and road grit.
  • Foam and hand wash: Apply a pH-neutral car shampoo via a foam cannon. Hand wash using a clean microfiber mitt, moving in straight lines.
  • Iron remover: Spray a dedicated iron remover across the stainless steel panels to pull out embedded rail dust from transport. Do not let it dry on the metal; rinse thoroughly inside a garage or away from direct sunlight.
  • Clay bar: Use a clay bar with plenty of clay lubricant to pick up leftover bonded surface contaminants
I think the fact it is bare stainless steel is the main reason that vast majority are wearing a wrap at this point. I haven't seen a "naked" one in a long time and the one I did see was tarnished and turning some strange yellow-ish, rusty-ish color.
I wonder how people detail the classic DeLoreans to keep them looking good? Other than sending them back in time...
I would spend some time and look up old posts and information on how people were detailing the old Delorean cars as they were stainless as well.
This came out over a year ago but in a recent video he said that’s he coated several cyber trucks and his customers are very pleased with the outcome.
It’s a long watch but it’s probably the best tutorial on how to detail one of these sardine cans on wheels.
