This is my first post! And I need your advice. I had my wheels painted matte black by a local rim repair shop 5 months ago. Immediately after that I coated the wheels with Gyeon Q2 Rim.
A month ago I had my car serviced at MB dealership, when they washed my car. When I went to pick up my car, I noticed (water?) marks on the wheels but had just assumed that they would come off after a proper wash and dry.
As you can imagine, they didn't go away after I used brake buster to clean the wheels properly. There are stains that appear to be streaky. Interestingly, these stains are mostly on the driver's side.
To cover them up, I reapplied RIM Q2 and now the stains are not as visible but still noticeable up close. These images were taken after I applied the coat. I should've taken before photos so you can see the stains more clearly.
What do you think caused this? Could the dealership used non-PH neutral cleaner? Still it doesn't add up because the stains are mostly on the driver's side.
I can think of another possible cause. After watching detailing videos on YouTube, I attempted to do DIY headlight restoration (that was totally unnecessary because my car is relatively new). I made a mess and polishing compound splashing all over the front bumper and the engine bay. This project took 2-3 weeks from the start because I had to order more sandpapers and compound, during which time the car hadn't been rinsed or washed. I can't remember if I inspected the wheels after I gave it a good wash but I think I would've noticed the stains if there was any. So I don't know where these stains came from.
Is there a way to fix this? Using a magic eraser / polishing compound came to mind but I didn't wanna make it worse.
View attachment 72418View attachment 72419View attachment 72420
