Steam cleaners?
mrckeys
Looking to buy a steam cleaner. Mainly wanting to use it on vehicle interior. Any suggestions from the community on the best steamer for money. If anyone wants to provide information that would be great.
VX5000 if you can afford it
I have a Mytee Firebird. It is adequate. Good heat. Wish I had higher PSI.
McCulloch MC1385...can be had for under $200 and it is wonderful!!!:xyxthumbs::xyxthumbs::xyxthumbs:
This is one of the steam cleaners that I had been looking at. Then the more I read it would talk about the boiler needing to be stainless steel. So I started looking at the Vapamore MR-100 PRIMO Steam Cleaning System.
Have you heard of this one? It is only another $100 dollars more, but I'm trying to justify whether a $100 dollars is work it.
That VX5000 looks pretty good. Looks like it comes with ever attachment known to man. I agree, if I thought I would be using this machine on a daily basis I would probably go with this one. And maybe if I do start using the one I get on a more regular basis I may consider this one. The current one that I have been looking into to start with is the
Have you heard of this one or have any opinions on it?
No, I haven't used the Vapamore, but let me suggest something to you. If you can afford it, always get the best machinery you can, period. A steam cleaner especially as its uses are limitless. Wait till your wife sees what it can do on tile floors! The uses for it in the house alone justify its purchase. I have 2 with a McCulloch I bought at Harbor Freight that I use in the house. If you're on a budget, it is a good machine; I've had mine a few years no with no issues whatsoever.
Thanks for the suggestion. I'll keep that in mind. Always love going to Harbor Freight.
VX5000 hands down. I do not use mine daily but when I do use it I'm happy I have it and works great.
I totally agree about the VX5000 if you have that kind of money to spend. I did research on steamers for around 2 weeks before I made my choice. The Vapamore is a great machine, but in the end I chose the McCulloch MC1385. The McCulloch steams for up to 2 hours, has a bigger tank, longer hose, and I think it has a little more psi. On the other hand, the Vapamore has a lifetime warranty and a stainless steel boiler. I would suggest that you get what you can afford because the 1385 does a great job. I only detail part time on the weekends, and I use my 1385 on every interior that I do and it works great. If you search the board on here, you will find a long thread about the 1385 that has some reviews, links, etc. Hope this helps!
VX5000 hands down.
Is the VX5000 offer constant fill ability or do you have to turn it off, let it cool down before adding water?
Can you use tap water or must you use distilled water?
The brush attachment, how do you secure a clean towel?
I've never used the VX5000 but I'm completely impressed with the Dupray constant fill models. You can use tap water and they have a very ingenious method of attaching a towel to the brush head that's fast and easy. A real time saver.
And why this is important is because if you are in fact cleaing anything that is really dirty you're going to go through a lot of towels and that means swapping them on and off often. If you click the link below for the full article at the end I have a tip for this aspect.
How To Use the Dupray Hill Injection Steam Cleaner
The size of the brush head is PERFECT for any standard size 16" square microfiber or cotton towel.
watermark.php
Simply fold the towel diagonally to create a triangle shape like this...
watermark.php
Place the brush head onto the folded towel like this with a little more extra space at the top. (not much just a little, you need some excess at the back also)
watermark.php
Use your finger or thumb to depress the spring loaded clamp....
watermark.php
Then simply pull the three corners of the towel up and through the open slots of the clamp....
watermark.php
Should look like this when done correctly...
watermark.php
watermark.php
This is steam coming out of the brush head on the low setting....
watermark.php
This is after making a single pass over the 4 black tiles you see on the floor behind the brush head....
watermark.php
NOW THIS IS WHAT'S REALLY COOL ABOUT THIS TOOL!
Most steam cleaners use a pressurized tank to hold the steam. What this means is that when you run out of water you have to TURN THE MACHINE OFF THEN WAIT FOR THE MACHINE TO COOL DOWN BEFORE YOU CAN ADD MORE WATER. This is a HUGE time killer.
Not so with the Dupray Hill Injection Steam Cleaner. This unit offers continuous fill, that means you can continually fill the tank with water as needed without having to turn the machine off and letting it cool down.
Here's the tank cap, note the hole in the top of the cap which is your first indicator this is not a pressurized steam cleaner.
watermark.php
watermark.php
This steam cleaner is on, it's at full temperature and I'm pouring water directly into the holding tank. No problems.
All you have to do is use a pressurized style steam cleaner one time to fully understand how important and desirable this feature is in a steam cleaner.
watermark.php
Mike I have yet to empty the tank on an interior. Once you do run out of water you can open up the lid add the water and let it heat up.
You can use tap water, however if you do you should use a little bit if CLR to clean the tank once a month and rinse it out. A person should NEVER run anything but water through the system.
It's always best to use Distilled water when using a steamer.
It comes with a large selection of brush attachments but the large triangle brush attachment has two clamps so that one can do the "Diaper Wrap with a towel to clean.
I'll post a photo once I get one.
I agree that's why I purposefully showed Distilled Water being added in these pictures....
watermark.php
watermark.php
That said, Dupray says it's not necessary. To me the cost of distilled water is low enough it's certainly won't hurt and it might help. Some people have some pretty foul tap water.
Really depends on your money and how many times you are going to use it. I went with a cheap mcculloch that works great for the weekends and cleaning my own car once or twice a month. If I did this as a business or weekly I would go with something like the vx5000 because of the reputation, warranty and parts used.
Agreed, I have heard a lot of good things about the McCulloch. For the amount of work I'm doing right now with steam this would probably be my best bet. If I see that I'm gonna be using it more regularly I will probably need to think about saving the money to get the VX5000. Thanks for the input.
I'd really like to have one like most professionals have. I'm sure they will be more time saving and hold up a lot better over time, but my wallet doesn't agree with that right now.:xyxthumbs:
The model I show above is $2,200.00
But if you want the ability to add water water on the go... that is the continuous fill feature, then the entry level Dupray model that offers continuous fill and comes with all the same attachments is this one,
Dupray ONE Plus Steam Cleaner
Hopefully, one of these days I'll be able to afford a big boy toy like that. Thanks for posting all the great information on the steamer. I will keep this information in mind when I decide to upgrade in the future. Thanks! :goodpost:
