I've never steamed anything. Do you hit some thing with steam, then wipe it with an MF?[/QUOTE
Lots of videos on YouTube. The most common method for fabric or carpet is to wrap the triangle tool with a microfiber cloth and scrub with that. You could do the same on hard plastics or switch to a different head. Common sense is important, I don't go near the electronics with my steamer for example.
Im thinking of buying the steamer at HF? How do you use it for the carpets? Do you steam then vacuum? #### steps made it sound like the steamer would vacuum too? Im confused ive never done it before
With the Bissell Symphony you canA steamer does not vacuum. It blows
hot vaporized water at what you are
pointing at.
I usually like to get something cheap to see if I like it enough to use it all the time.Don't even waste your money on that.Literally piece of junk.Bought 2 then the 3rd one I bought the warranty for 14.00 .Now the cap is messed up and not building pressure I give up.Invest into something good if your going to use all the time.Even the attachments suck.There will be someone chiming in that its good.Believe me its not.
I do the same thing. I bought a cheap one on Amazon and love it. I do prefer my extractor for extra soiled seats and carpets, but I love the way it cleans lightly soiled fabric and hard plastics. Kind of leaves a ordorless smell to a car, good thing if the car smelled beforehand.I usually like to get something cheap to see if I like it enough to use it all the time.
If your doing this professionally get something like a VX5000. This is a very versatile machine. To clean seats or floors just wrap the triangle head with a towel or microfiber. The steam will emulsify any soiling in the fibers and force it up into the cloth. Much faster then my extractor. I now only pull out my Mytee on truly destroyed fabrics.
how is the VX5000 better than the McCulloch Heavy-Duty unit for $130? is the steam hotter than the cheaper unit? i understand the water tank is bigger and it will most likely last longer in the long haul but aside from that what else does it offer above and beyond the $130??
also what you using after you clean via steamer? do you use a wet/dry shop vac or just a brush and towels to clean?
You can fill it faster once the initial tank is empty. On the MC1385, you have to shut the unit off and either wait to fill it, or go VERY slowly as the initial pour will gieser out of the top until the element and tank cool down suffiently before you can fully fill it. Once it is full it will take about 15 more minutes for it to heat and pressurize again. I can get 1 to 1:15 full time use out of a a 32oz full tank of distilled water. IIRC the VX will also work with tap water where the MC will require distilled.
I love my MC1385 and find it works just great for what I do which isn't focused on interiors. If I did them regularly, I'd invest in a steam extractor.
My routine that I find very effective is this:
Vacuum the interior
Pre-treat an area that I will work on and complete within say 15 minutes. I use either Ultima Interior or Folex. I then use the MC1385 Steamer to help break up and emulsify any gunk and dirt. Agitate with a brush where needed; then extract with my small steam extractor filled with pure hot water and a splash of white vinegar. Where needed I will go over it again with steam and then wipe with a white terry towel. I buy bags of them for cheap and they work very well.
Again, all in all for those not focused on interiors day in and day out, it works very well and is very inexpensive to start up doing.
what steam extractor are you using??
McCulloch MC1385. I use it a lot around the house too which makes it nice.
