I can clean carpets, seats, and the entire interior faster and better than I can with and extractor.
Customers are able to have a dry interior by the time they pick up the vehicle rather than have to wait for the seats and carpets dry for an additional day or two.
Here's a tip... Get a sturdy plastic table to clean floor mats. This will save your back and your knees because you won't be cleaning things like floor mats on the ground.
2: No chemicals involved, perfect for people that are chemical sensitive.
3: Introduces very little water to the surface so carpet, fabric and upholstery dries faster.
4. Hot steam loosens the bond between the fibers and ground in dirt and grime better than cold cleaning methods.
The unique feature about the Dupray Hill Injection Steam Cleaner is that you can refill with water on the fly as the water tank is NOT pressurized. Simply loosen and remove the cap on the water tank and add water as needed.
No need to turn the machine off and wait for it to cool down so you can safely add more water.
