IMHO: No.Is it good idea to use steel wool
to clean windshield?
Yes...In a heartbeat.would steel wool remove dirt?
0000 grade is fine on glass
Count me on the "don't use steel wool on glass" gang...
I don't use steel wool on glass, never have and never recommend it.
I know there are a lot of guys and even detailers that recommend it but steel scratches glass. Just because you cannot visually see the scratches doesn't mean they are not there.
Plus there are a lot of glass polishes available that are safe, no risks at all.
I bot some plastic razor blades from AG recently. Just to have some in case. Haven't tried them yet. EZ-grip on AG's front product page.
I haven't had any adverse affects from using 0000 steel wool. I have also used razor blades with a window cleaner.
IF you use 0000 steel wool, PLEASE be sure it's on a dry window and use nothing that would be wet.
Some FYI, I've used 0000 steel wool to clean the plastic chrome pieces of my front grill and never created any scratches.
I find that believing that I'm anywhere close to
comprehending why anyone would use steel-wool
anywhere near: any part, of any vehicle...
to be utterly inappropriate!!
Because it will cause the steel wool to rust.......... don't believe otherwise.Hi, could you please explain why use steel wool on a dry window? I've used it for years, but like clay, I use a lubricant with the steel wool so you aren't tempted to rub harder and it allows the steel wool to just glide lightly over the glass.
